Question about Bose 3·2·1 II System
Question on Bose 3-2-1
Can I hook my old Technics turntable to my new Bose 3-2-1 and listen to my old vinyl?
  • duneyork Apr 25, 2009
     I have attached my old Technics turntable to the Bose but I have to turn the BOSE volume upto about 80 to hear the music- I think because the TT is analog and the Bose is made for digital audio- not sure if using a pre-amp or a Turntable with a built in ( like the ION) would help or not?
  • 33 Answers
Hi! you can hook up .. first if your bose amplifier have a phono input you can put it plug and play. but if no pre amp phono input you have to buy or provide (from turntable to pre-amp phono to bose)  to heard and listen to your old vinyl.. mk2 batallion.....
Posted on Jul 09, 2009
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
I need to to hook up my turntable to my bose system
As long as the Bose has a spare audio socket you can do it. You however will need a device called a "Magnetic Cartridge Preamp". Otherwise all you will hear is the sound at a very low level.
Feb 10, 2013 | Panasonic Technics SL-BD22D Turntable
Technics sl dz 1200 no vinyl play
is anybody have solution for this? i have the same prob...
Apr 11, 2012 | Panasonic Technics SL-DZ1200 Turntable
Does my turntable need a new cartridge? I have a Technics SL DD22 which hasn't been used in a while. I hooked it up to a Bose receiver which works fine (hooked up an i pod to it before) & it plays...
The output from any regular turntable is far too low for most amplifiers to handle. You need to either run the output through a pre-amplifier first to bring the signal up to line output levels suitable for most recording devices and amplifiers or run it into an integrated amplifier which includes the pre-amp stage.
If your Bose receiver specifically includes a turntable input then it has a pre-amp built in, but as so few folks use turntables any more very few devices have the correct input. Pre-amps are still easy to obtain and can be very cheap, but cheap ones produce a noisy and unpleasant output which is magnified by the amplifier. If ever there's a choice to be made, spend the money on the pre-amp and go budget on the main amp.
I hope that I've saved you wasting money on something you didn't need. Please take a moment to rate my free answer.
Sep 24, 2010 | American Audio Vinyl 101 Direct-Drive...
Technics 1210 tonearm skates when cueing vinyl backwards
I've seen this on technics turntables before. Try tightening the screw on the arm.
May 20, 2009 | Technics SL-1210 Turntable
All my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
Feb 17, 2008 | Technics SL-1210 Turntable
Pitch problem
check it.
http://www.repairnyc.com/
These guys are authorized technics service.
Jan 05, 2008 | Technics SL-1210 Turntable
Drive belt has come off.
Ok.Thats a difficult part to explain on a pick up.So listen up and give attention.Take off the plate of your driver and adjust the belt from the down side of your plate where there is a circle.put it in there and grab the belt to one side and adjust it to the "turner"then put your vinyl and play it.
Aug 15, 2007 | Technics SL-BD22 Turntable
Bose 3·2·1 II System Logo
854 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
