Question about Pioneer CDJ-1000 CD Player
Error - 8403 on cdj 200 not reed the cd - Pioneer CDJ-1000 CD Player
  • 135 Answers
Can't find Error 8403 in the service manual. Please advise the correct error code and I'll see what I can find out for you.
E-7201 TOC READ ERROR 26: TOC data could not be read.
E-6002 DSP PROGRAM
DOWNLOAD ERROR
62: The program cannot be written in the DSP.
E-8301
PLAYER ERROR
(Startup error)
12: The desired address could not be searched.
15: Address data could not be read.
22: The Focus Servo could not be closed.
91: The pickup could not be returned to the inner track.
E-8302 PLAYER ERROR
(Abnormality in playback)
E-8303
PLAYER ERROR
(Abnormality in writing to the buffer)
99: Abnormality in writing in the buffer
E-8304
MP3 DECODE ERROR
(Abnormality in decoding)
Abnormality in decoding ∗∗
E-8305
DATA FORMAT ERROR
(Inappropriate data format)
A data format other than MP3 was used. ∗∗
E-9101 MECHANICAL TIME OUT 90: Abnormality in the disc-loading mechanism (TIMEOUT)
Posted on Jul 19, 2010
Error 8301 comes every for any cd.
8301 error is an error during startup. It should clear if you press the eject button, which could mean something blocking the track or sensor. or call 1-800-872-4159
Sep 23, 2013 | Pioneer CDJ-200 CD Player
CDJ-200 keeps ejecting disk without reading it. Tried to clean with a disk, and with compressed air, but it's still ejecting any CD that I put into it. It was working fine while I was mixing, and then just...
hii there,
Please also let me know if u get any error msg too. If dont get any
error msg. Please try to clean compartment of ur CDJ. But you have to open ur CDJ than clean it. If it does not work again. Then ur
CDJ need adjustment or alignment.
thx,
djajay
Aug 09, 2010 | Pioneer CDJ-200 CD Player
Eror 9101
this error is for Mechanical time out. Disc inserted cant be read in given time. There may be dust or other particles in compartment of CDJ. Please make sure if you can open it yourself and clean the compartment.
Thx,
djajay
Aug 04, 2010 | Pioneer CDJ-200 CD Player
I have a CDJ 200 cd player the power when turned on there is no display YASH
Hi Yash,
pls make sure and check the fuse of your CDJ. Also check the power output that is 240v or 110v.
thx,
djajay
May 25, 2010 | Pioneer CDJ-200 CD Player
No audio on cdj 200 after a power failure
check the fuses to see if they are any good
Feb 17, 2010 | Pioneer CDJ-200 CD Player
Pioneer cdj 200 wont read discs
Hi, try cleaning the lens with a cleansing disk. if this doesn't produce results, it will confirm a major issue within the lens assembly. you will need to replace the lens assembly in this case. it is unable to track or read in this damaged sate.
May 19, 2009 | Pioneer CDJ-200 CD Player
Queing up on cdj 200
In order to set a cue select th button IN/REALTIME CUE once you do that you an press the CUE button located next to the play buton.
Dec 28, 2008 | Pioneer CDJ-200 CD Player
Pioneer cdj 200
the fuse was blown inside!!
Aug 11, 2008 | Pioneer CDJ-200 CD Player
Cdj 200 will not turn on
It actuall might be the fuse or there is a little short circut switch on one of the boards. That switch could have gotten moved.
Nov 20, 2007 | Pioneer CDJ-200 CD Player
Pioneer CDJ-1000 CD Player Logo
1,293 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
