Question about Raymarine RC400 GPS Receiver
Its say error 0x4001
Its something about the navigations charts when I start up the gps I cant use the the keys because of the error code call: 0x4401
  • wdumais Mar 13, 2009
    I'm having the same problem and called for a repair. Before I even explained what the problem was, they said that to repair the RC400, it was a 300.00 flat rate. I guess that is because it is a discontinued model. Very frustrated with that answer.
Error 0x4001
Posted on Aug 10, 2011
Keeps beeping and displaying approaching turn
The "Approaching Turn" message is coming from an active navigation on your device. To turn it off, press and hold on the left side of the bezel (GPS), then press the lap/reset/quit key to exit the compass screen. You should then be in the GPS menu. There should be an item in this menu titled "Stop XXXX" where XXXX is "Navigating", or "Back to Start", or something like that. Select that option, and it should stop the navigation, and eliminate the "Approaching Turn" messages.
Sep 29, 2013 | Garmin Forerunner 405 Handheld GPS...
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Humminbird 798 ci xi HD Combo - While traveling at 32 mph the mph and distance traveled started to flash. I could not get them to work so I restarted the locator and then they were no longer on the...
Do a master reset on the unit. restart and cross your fingers. If this does not resolve the problem you probably have an internal fault with the GPS unit.
Aug 06, 2013 | Humminbird 798ci SI Combo GPS Receiver
I have a 276C and have a marine charts card in it for navigation. When I have the GPS hooked up to my lap-top, it there a way to view the marine chart on my lap-top screen? I would think this would be a...
Hi!
You require a chart navigation or free viewer program on your laptop to decipher the information your GPS sends and to interface with it.
There are a few of these programs available, but we opted to purchase CAPN Voyager (The CAPN) many years ago and have been quite happy with it for the 16,000 miles of coastal cruising we've done. The program allows us to see our progress in real time on the computer screen and is easy to use
Prior to that, we used Maptech's free chart viewer which allowed me to plan routes and then put the lat/lons into the GPS unit, but had no interface with the GPS to allow us to navigate in real time.
Hope this helps.
Jan 23, 2011 | Garmin GPSMAP 276C GPS Receiver
What memory card does the 5505 take
CLICK HERE for all the info.
CLICK HERE for the Manual.
Your specific question's answer is on page 7 of the manual:
C-MAP™ chart cards have chart details required for navigating in a particular region. When a chart card is plugged in, the extra details automatically appear on the TRACKER chart display.
The TRACKER can use NT, NT+ and NT-MAX cards.
C-MAP™ user cards are used to store navigation data. Each user card expands the TRACKER memory and allows the data to be transferred to another TRACKER easily (see section 14).
Note: The older 5 volt user cards are not supported.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2010 | Navman TRACKER 5505 GPS Receiver
I have poblem with my gps
i have a nextar w3g, and this gps is running with windows CE, is possible the problem to be a virus or some othe errors you can find in every other windows sistems.
Aug 30, 2008 | Nextar X3B GPS Navigation System
Communication Timeout
Under connection settings switch off the "beam" - apparently there is a conflict between the IR beam port and one of the ports used by the GPS system. Has worked for me.
Oct 26, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
Communication to Offshore Navigator light
The internal memory battery is dieing. It will eventually stop completely unless you get a new battery installed.
Jul 08, 2007 | ICOM Informatique GP-270ML GPS Receiver
MY FX324 COLOR WILL NOT TURN ON
Switch off then push together - MarkMOB + Goto + Power
May 29, 2007 | Magellan FX324 Color GPS Receiver
Raymarine RC400 GPS Receiver Logo
967 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
