Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Trim ring around dryer door removal? duet ywed9400su
How to remove trim clips withou breaking them on the trim ring around the door so i can repair control panel modual? thank you..
SOURCE: I need to clean out the dryer duct and inside.
You just need to remove the two small bolts at each bottom corner of the panel.
Posted on Sep 21, 2007
  • 189 Answers
I've searched around for DIY instructions, but those are exceedingly difficult to locate. It seems that Whirlpool wants you to buy their Door Reversal Kit for 11.99 in order to accomplish this.
Posted on Jan 07, 2008
  • 1073 Answers
SOURCE: Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
remove the lint fiter and remove the two phillips screws then lift the top up
you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
Posted on Apr 30, 2008
SOURCE: Whirlpool duet electric dryer, not getting any power
Mine shows a faint light behind the control locked indicator and the timer is dimly lit on the two middle horizontal bars (middle of the eights). They go off by pushing various button combos. If I unplug it for a week I can get the control to work for a few minutes.
I replaced the control board, it worked for 5 minutes, then back to nothing. I want to replace the interface but would rather not waste any more money.
I dont want to check every wire for continuity. If someone has fixed this problem, please let me know.
Posted on Aug 15, 2008
  • 5911 Answers
SOURCE: Whirlpool Duet Dryer panel says
The following link explains how to correct a control lock problem:
If this does not correct your problem, please post back and let me know, so that I am assist you better. I hope you find this information helpful.
Posted on Jul 11, 2009
Whirlpool duet dryer ring around the door keeps u hinging. They are metal and what I've tried is pushing them back in.
The clips are first secured to the ring. Then, the clips themselves go into holes around the door.
They are somewhat spring loaded and you'll need to compress the fingers on the clips to remove them from the holes. Then, position the clips properly on the ring and push the slotted section (on the clips) onto the plastic tabs around the inside of the ring. Then, use a soldering iron to melt the tab heads so the the clips will stay on the ring. Then, just line up the holes on the dryer with the clips and start pushing them back into the holes.
Remember, make sure the clips are aligned properly, else they won't line up with the holes.
Dec 29, 2014 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
How do i remove front panel on a Whirlpool wfw96heac
I have a whirpool duet qnd to get the front panel off you have to take out the soap drawer and there is a bolt there that has to come out.
also I had to pry off the trim piece around the control panel to get to the rest of the bolts. I did it carefully and it came off without breaking.
May 03, 2014 | Whirlpool WFW96HEAC R 4.3 cu. ft. Duet...
Removing rear door panel 2004 subaru outback
Remove the trim ring around the inside door handle by pulling it up and towards you first, then downwards.
Remove the switch panel. There are two spring clips holding it. Lever up carefully on the top end edge first, then push the panel towards the car floor. Disconnect the electrical connector.
Remove the screws behind the door handle, under the switch panel mount, and on the armrest.
Dislodge the 7 trim clips around the edge of the door trim, starting at the lower edge and working up. Lift the door trim out of the top channel.
If you remove the plastic sheet, take care not to tear it, a spatula is handy for this.
Apr 15, 2012 | Subaru Outback Cars & Trucks
This was a very poor design from the factory ..The clips attach to the trim ring at the factory by plastic welding (MELTING) them in place to the stanchion's, in working on many of these sometimes you can super glue them back in place, but you will have to remove the trim ring completely to do it. other times i had to just replace the entire ring as it was to far gone to repair Just a bad design guess they didn't think it would ever have to be taken apart
Nov 15, 2010 | Whirlpool Dryers
How do you take off inner driver side door panel with out breaking the the snaps and panel itself
Sometines the panel retainers do break, they are available at most parts stores, you should use a special tool to remove them (pic below)
Front Door Panel: Service and Repair
Trim Panel Replacement - Side Front Door
J 38778 Door Trim Pad Clip Remover
1. Remove the inside handle bezel (2).
2. Remove the fastener (1).
3. Lift the flap (1) in pull handle opening.
4. Remove the two fasteners (2).
5. Remove the two fasteners (1) from bottom of trim panel.
6. Using the J 38778, release the eight retainers.
7. Lift upward and outward on the door trim panel.
8. Disconnect the door latch cable from the inside door handle.
8.1. Pry the tab on the cable outboard while pulling back on the cable.
8.2. Unhook the collar portion of the clip from the cable attachment.
8.3. Push upward on the bottom of the cable attachment to disengage the cable from the handle clip.
9. Disconnect the electrical connectors.
10. Remove the door trim panel.
1. Partially install the door trim panel.
2. Connect the electrical connectors.
3. Connect the door latch cable to the inside door handle.
4. Raise the trim panel over the lock knob and align the fasteners (1) in the holes in the door assembly.
5. Secure the trim panel to the door assembly by applying sufficient pressure on the trim panel.
NOTE: Refer to Fastener Notice in Service Precautions.
6. Install the two fasteners (2) under the inside pull handle opening.
Tighten the fasteners to 2 N.m (18 lb in).
7. Install the inside trim panel cover fastener (1).
Tighten the fastener to 2 N.m (18 lb in).
8. Install the trim bezel (2).
9. Install the two fasteners at the lower portion of the trim panel.
Tighten the two lower fasteners to 0.5 N.m (4 lb in).
Oct 30, 2009 | 2000 Cadillac Seville
Where on line do i find how to get the door panel off to repair the window regular
If this is a front door.. There is one screw in the top in the triangle covered by a plastic circular cover. The rest of the door is held on by plastic push clips. Use a trim panel pry bar to remove the panel. Stick the pry bar between the door and the trim panel around the clip when prying. The clips break easily so use caution. They are a dealer only item and cost about $2 each. Be careful when removing the panel, I'm fairly certain there aren't any other screws but it's been a while since removing one on a Grand Cherokee so don't go yanking anything too hard. Once the panel is hanging there just unclip the door handle and lock rods and any electrical connections.
If this is a rear door it should be very similar except for the screw in the triangle.
Oct 25, 2009 | 2002 Jeep Grand Cherokee
How do you remove the door liner on a 1999 surburban?
first remover the trim ring from around the inside door handle by using a flathead screwdriver between the 2 plastic pieces at the top and bottom of the trim ring and it should pop off ,then take the 2 screws out of the arm rest,then pop the plastic piece off by the mirror mount by pullin out on it then just work your way around the panel with the screwdriver and pull the door panel away from the door,there are just plastic clips that hold the panel to the door,after that just unplug the window switches once u have the panel off the door,hope this helps
Sep 05, 2009 | 1999 GMC Suburban
Changing door speakers
The clip behind the handle requires a specialty tool available at any autoparts store. it is shaped like a U, but has little tabs on it to catch the ears of the clip.
After removing the clip, remove the plastic trim by the mirror... and a little trapdoor inside the door handle cup will have a screw in it.
The rest are just push-clips, so start at the bottom, and pull toward you... working your way around the door.
The tool looks like this...
Dec 29, 2008 | 2005 Chevrolet Cobalt
Replace side door handle assembly
Remove the snap ring from under the inside door handle and plate (a rag around the base of the handle and a left-right tug on the rag may loosen it, or look under it & pry the snap ring off with a small hook tool
Remove the door lock knob bezel; remove the screw & slide it rearward
Remove the door trim; Remove the two clips; slide a thin, flat wide tool under the panel and pry towards you, there are 8 clips to dislodge
Pull the door trim straight up once all of the clips are loosened.
Sep 23, 2008 | 1992 Toyota Previa
Exterior door trim
The molding in the middle of the door clips on. Remove interior door panel to access the clips, they usually break off. Or do you mean the black tapes (stickers) around the window opening, they are just stickers. Take a heat gun to loosen glue and peel off.
Jul 01, 2008 | 2001 Hyundai Elantra
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
469 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
