Question about GE JVM3670 Microwave Oven
MY GE JVM3670SK04 Microwave Hood Vent Fan Continuosly Runs?
My GE Spacemaker Microwave Hood Vent Fan is Continuosly running! It didn't do it before. Everything else works fine on the unit but I can only press the fan button and it goes to HIGH or MED, not off? What can I do to fix this? We've tested everything else and all the fuses and thermostats are good, there are no burn marks on the Smart Board everything reads fine. Please help cause it's ANNOYING!!!
2 Suggested Answers
SOURCE:
heatman101
  • 43501 Answers
SOURCE: GE Spacemaker XL1800 microwave suddenly
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ==-
Posted on Sep 26, 2011
Exhaust fan direction
You can usually recongure the outlet on the vent to just vent into the room,but if you aren't going to use it,not an issue.
Dec 18, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
GE Spacemaker shorting
From your description the cooling fan is not running, causes! open motor winding, seized motor, or defective door switch, you will need somebody to assess
Jul 19, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
The active vent remains open when microwave is off.
Without a full model number, we can only give a general answer.
It's most likely an issue with the louvre motor or the controller board which runs it.
If any of the fan, lights or turntable are not working, that indicates a controller problem, which we regularly repair.
Let us know if we can help further.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Oct 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 microwave suddenly didn't work. All buttons on the front panel except "Clock" don't work. Open the machine, shorten the thermostat, the vent fan runs automatically....
heatman101 ==-
Sep 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
Ge Spacemaker XL 1800
SOME BUT NOT ALL OVENS HAVE RELAYS TO TURN THINGS ON AND OFF CHECK THE OVEN TO SEE IF YOU HAVE ANY
RELAYS AND SEE WHAT THEY DO.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
New microwave; loud fan when heating items
Since you say it's new, it should be under warranty. I would call GE (see your owner's manual) to get a local authorized service center. Then while you're on the phone with the service center, you can start it up and hold the phone close to it to demonstrate to the technician how loud it is. They should be able to tell you if it will be covered under warranty so you get it fixed free.
Mar 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave with vent fan
hi possible magnetron problem but also check highvoltage capacitor and diode . the process of ellumination is the only way to help u .first disconnect connegtor to magnetron and switch oven on if noise goes away eureka repeat with other components
Mar 18, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM3670 Microwave Oven Logo
71 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
