Question about Canon NP 6035 Copier
Adjust problem I like to know the mening of adjust and edit and the valio for evry step for canon np 6035 and what i can do with eror 500
    Sergeant:
  • 199 Answers
Sorter error
Posted on Feb 26, 2009
Set duplexingunit canon NP 6035
codes e002 et e004 canon copier np6035
Jul 24, 2012 | Canon NP 6035 Copier
CANON NP 6035 The error code E224
Bagaimana cara mengatasi error e224 ???
Salam Sukses By KBG.
Feb 27, 2011 | Canon NP 6035 Copier
How do you replace toner for canon np 6035 copier
open the front cover, then you will need to slide out the piece the toner goes into, upper right side. Set the toner cartridge on top. You will see a tab to pull toward you, so the toner will drop down into the copier. Push the tab back in. Then push the cartridge toward the back of the copier a little and pull up.
May 15, 2010 | Canon NP 6035 Copier
How to replace the cleaning web in Canon NP 6035 copier?
You must remove the fixing unit and just look how is assemblled and dissass. it or you can call the service
Jan 09, 2010 | Canon NP 6035 Copier
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
Oct 01, 2009 | Canon NP 6035 Copier
E 065 error code
change the composite power suply board
Apr 27, 2009 | Canon NP 6035 Copier
Change language
not sure you can????
Anyway to get into service mode,
open front door
bottom left next to green knob there is a pinhole
insert paper clip and push on switch
you should be in service mode
if not you must cheat the front door while it is open (folded paper in slot will do)
then go through the steps
once in service mode you should be able to scroll and check for language
Aug 10, 2008 | Canon NP 6035 Copier
Printing on Canon NP 6035
I check www.usa.canon.com and couldn't find anything that came close to that model number. You should contact them directly. It may require a copier dealer in your area to get one for you.
Jun 26, 2008 | Canon NP 6035 Copier
Canon np 6035 copies to dark
He is probably adjusting the exposure voltage. If you take a flashlight and look inside the small hole, you should see either a "+" or a "-" on a plastic part. Turning it clockwise will increase the voltage, and counter clockwise will decrease the voltage.
If you are going to do this, I would suggest using a plastic screwdriver to turn the "Pot" (Potentiometer)
Doing with by yourself will be a hit or miss effort. Also it is not recommended doing this without knowing what you are doing.
FYI, If you are going to turn the "Pot" on your own, I would suggest turning it very little and testing a copy, and then doing this again and again to make sure you are helping the situation or hurting it.
Good luck.
Hope this helps.
If I have helped, please post a feedback and a rating towards me.
Mac
Feb 28, 2008 | Canon NP 6035 Copier
Canon NP 6035 Copier Logo
83 people viewed this question
old marine
old marine
