Tv will not turn on
My tv will make asound like it is coming on but will not. Standby Light flashes 5 times. When I press the power button, the TV sounds like it's about to come on and then nothing. This happened after my 18 month old son pressed the power button again and again and again...
  • 790 Answers
Hi
maybe you have defective power oscillation this issue needs to check for a qualified technician
Thanks!
Posted on Feb 25, 2009
My sony kdl-46v3000 standby light blinks 5 times tv wont turn on
The TV enters standby mode when there is no signal for 30 seconds. https://docs.sony.com/release/KDL46V3000.pdf
I searched standby using Ctrl+F and found this information. It seems you should be able to bring it out of standby using the power button on the remote. You want to make sure there is an input connected and if it is connected to a PC that the PC isn't telling the TV to go into standby.
Try pressing the input button and changing inputs once you press the power button and the Standby is flashing.
If this doesn't work you may need to contact Sony Support.
1-800-222-SONY(7669)
Apr 10, 2014 | Sony Bravia V-Series KDL-46V 46 in. LCD...
Sony Trinitron color TV 36 inch
hello,
You should examine the input power of the TV. If you dare to open the back of the TV You should examine the by using the tester to test the continuity of the voltage input of the TV. i guess voltage regulator need to be tested.
Be careful high voltage inside the TV.
The best way is to contact the vendor of the TV or sony service center in your area.
may this help,
melnavz
May 12, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
I currently have my KV-27FS120 Sony TV connected to a cable box, which is receicing 100% signal. However, my television when powered on, the picture will tend to flash at times for a half a second and then...
Check whether the issue occurs with all the external devices like DVD Player, VCR, etc. If the issue is occurring with all the devices then the issue is with the TV.
Try these steps to check whether the issue is resolved.
1.Disconnect the power cable and connect it to a different working wall outlet.
2. Disconnect surge protector if you are using any.
3.Power reset the TV by turning it OFF for atleast one minute.
3. Reset the TV to the Factory defaults.
To reset the TV, turn it ON.
Press the RESET button on the Remote and press the POWER button on the TV at the same time. Now, TV will turn OFF and then back ON automatically.
Now, proceed with the Auto Program.
Check whether the issue is resolved after the Auto Program is finished.
All Sony TVs have a self-diagnose mechanism where the Standby light blinks to indicate that there is an internal malfunction in it.
Note: Your TV does not have the replacable LAMP.
If the issue persists TV requires service. Contact nearest Sony authorized repair center,
Jul 22, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
LCD tv won't power on...
The power board is dead,replaced the board.Well get the power back.Tries Shopjimmy.com,Ebay.com for the part.
Jan 26, 2010 | Televison & Video
I have no picture and the timer/standby indicator flashes seven times. i cant find a list of the codes on the internet for what that flashing light means
seven blinks is over current protect try to turn the tv on using the sony original remote with this button sequence press display 5 volume up then power if the tv comes on replace ic8002 on the power supply if it doesn't I would still try that fix very common on sony tv's
Jan 24, 2010 | Sony KP-48S70 48" Rear Projection...
Sony bravia tv not working
Hi Elaine!
Please follow the steps mentioned below to troubleshoot the issue:
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
