Question about JVC KDAVX44 Car DVD Player
Loosing all ive saved when i turn the engine off
Turn engine off cd goes back to number one.loose all the radio stations
    Novelist:
  • 152 Answers
Easy fix, There are two 12+ volt feeds that should be connected to your unit.
1. Constant feed = 12+ volts that supplies power to the units memory all the time.This wire can be connected from the original radio connector wiring so long as it supplies constant 12+ volts, or be pulled from the battery, with an in-line fuse.
2. Switched feed = 12+ volts that only supplies power when the ignition switch is turned on,This wire can also be connected from the original radio connector wiring so long as it is a switched feed, also with an in-line fuse.
During installation ether these wires were swapped or the constant feed (memory wire) was not connected.
Good luck...
Posted on Feb 24, 2009
Radio frequently just stops broadcasting and eventually comes back on
Peggy, Is the radio actually switching off or do you just loose the radio station. If radio is shutting off, there must be a bad wire/ plug connection, loose plug, or maybe bad ground.
If loosing station, have Arial/antenna connections checked, maybe upgrade to better antenna. Some stations just do not send out a strong signal which can also cause loss of station.
Mar 29, 2016 | 2009 Toyota Highlander
Why do my settings reset in aftermarket stereo of my 92 mercury cougar
As well as the normal 12 volt line form the ignition switch, there is a 'permanently on' 12 volt lead, which keeps the clock and memories going even when the ignition is turned off. It sounds like the installer has missed connecting this one.
Aug 28, 2012 | Pioneer Audio Players & Recorders
Radio stations wont store once key is taken out
if the unit only looses radio station presets then there is a defect with the unit. if the unit looses all its memory, (clock, stations, settings) then there is an issues with your aux power. basically you have the main power connect properly so it turns on the unit while the cars is on but the aux power keeps those settings.
Mar 08, 2011 | Virtual Reality VRCD500-SDU CD Player
Radio goes out when start engine. Loses all settings.
Your radio might be shorting out. I would make sure the ground wire hasn't come off.
Jun 01, 2009 | 2001 Toyota Camry
Can't Set Presets for Fm radio
when u get it to the radio station u like.... on ur cd player u should have buttons 1-6 or somethin close.... when ur at the station u want to be preset... pick a number 1-6 and hold that number in for about 5 seconds... it should notify u some how... it should preset itself when u do this
Jan 16, 2009 | Sony CDX-M8800 CD Player
How do i program the sony cdx-m8800 to save the radio stations?
Manual
javascript:moreinfowindow('http://www.docs.sony.com/reflib/docget.asp?manualid=14979&template_id=1&region_id=1&DL=',600,560,10,10,'Manuals')
Jan 02, 2009 | Sony CDX-M8800 CD Player
Jvc kd g521 car cd player
Have you checked the cables? It appears that you have connected the wire for ignition directly to the power in and the direct +12v to the ignition cable. When turning ignition off, the memory is then emptied.
Jul 06, 2008 | JVC AM FM CD DET FACE CAR STEREO
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Dec 27, 2007 | Audio Players & Recorders
Tuning the radio
You have two "hot" wires going to the radio. One is the main B+ power and the other is for the "mem" function which keeps clock time and radio station presets in memory. Make sure that you have 12 volts to the memory wire (blown fuse?) If you do then you may have a problem that requires a trip to your local repair guy. Do you loose your preset stations when you turn off your car and leave the face in place (wait several minutes before turning car ignition back on)? If that is so, then you most likley don't have B+ to your memory wire. Good luck.
Aug 16, 2007 | Sony CDX-L480X CD Player
JVC KDAVX44 Car DVD Player Logo
101 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
