Question about Philips 52PFL7422D/37 TV
My Philips LCD model 52pfl7422d/37's red light blinks 6 times slow and then 3 times fast. Any idea what disaster this coded message refers to?
  • jennilsal Mar 30, 2009
    I have a similar problem. but with the blue light flickering off. a series of clicks and the tv won't turn on.
  • Anonymous Mar 24, 2014
    6 3 error code
  • 90 Answers
If no sound and no picture -- check the fuses and disconnect all cables -- wait one day and re connect - if you solution -- might need a new power supply board
Posted on Mar 03, 2009
I have a Philips plasma 42pf9631d/37 that doesn't turn on. I get 6 slow red light flashes and 3 fast. Is this easy to fix?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Aug 25, 2015 | Philips Televison & Video
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
Phillips TV Model: 52PFL7422D/37 Purshased this TV Dec 16, 2007. No I have blank screen with the TV blinking a read light at the left - the red light flickers - blink, blink,blink,blink,blink then 3...
First place to check is the power supply board. I have not repaired this particular model. I'm very certain you have two bad capacitors in the power supply. This is a classic problem for Philips flat TVs. The capacitors will be bulged or skinned. Be sure to replace them with same values. I would certainly gamble my time removing the power supply for inspection. Spending a few bucks on two capacitors may prove good. A working TV is near. Thanks for asking and show all hands of support!
Jun 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
I replaced three cans. they were bulged on the top. i plugged the tv in and it did the same thing. i said it blinks 4 times fast but it is only three. blink code says 3=RESERVED. i pulled the the y-sustain...
Philips lists 3 models of your TV:
1) 50PFP5332D/37
2) 50PFP5332D/37B
3) 50PFP5332D/37E
User Manual for your TV (actually for the 50PFP5332D/37E):
http://download.p4c.philips.com/files/5/50pfp5332d_37e/50pfp5332d_37e_dfu_aen.pdf
The user manual doesn't document the logic board blink codes for errors.
What this tells me is that the TV went thru two revisions before reaching version E.
in case it helps: Philips Customer Support: 1-888-PHILIPS.
If they can't help otherwise, they can at least tell you if your set is eligible for warranty service.
Mar 24, 2011 | Philips 50PFP5332D 50 in. Plasma...
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
My philips tv flat screen keeps shutting off and a red flashing code starts blinking?
Not sure what code since you didn't say, but here is the code breakdown.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 27, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
I have a Philips 50" Flat HDTV model 50PF9431D/37. Problem with screen turning on. I get sound. I get 9 quick flashes in red. Then after unplugging and plugging back in several times. It then blinks...
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
Aug 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Philips 52PFL7422D/37 TV Logo
598 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
