Remote control not functioning correctly
Remote control doesn't do anything other than change the picture format, this happens regardless of which button is pressed.
  • clking00 Feb 24, 2009
    The red light is on, I've read the manual, this says it's in standby mode, would this make any difference?
  • 3 Answers
The green light will not on
Posted on Feb 24, 2009
Need a code for a tevion lcd 32081D to activate sky remote
Hello
Check these codes.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
Oct 16, 2011 | Televison & Video
Code required to programe sky remote control for murphy 42884t2lcd
Hello
Three digit remote code with Sky with Murphy TV are:
132 244 191 502 100
Please note:
In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press TV followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Sep 21, 2011 | Televison & Video
Code for Sky remote for AlbaALCD15DVD2 tv Thanks TH
Hello
Sky remote codes to check with Alba TV are:
037 065 246 399 263 064 446 609 275 077 515 244 398 239 400 459 191 383 607
696
705
742
471
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
If all functions do not work correctly, then repeat steps 1 to 3 and work through all the relevant 3 digit numbers from the Sky Plus remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Sep 20, 2011 | Televison & Video
Hi need code for sky remote for sony kdl402530
Hello
Sky remote codes to check with Sony are:
533 038 039 064 102 130 505
679
505
5* Point the Sky+ remote control at the TV and try the volume button.
OK.
Aug 25, 2011 | Televison & Video
Can't find sky remote code for grundig gu37fhd1080
Hello
Sky remote codes for Grundig are:
563 582 515 098 584 219 104 233 223 065 471
Aug 20, 2011 | Televison & Video
Sky remote control code needed for lg tv - model 37lk450
Hello
Setup codes for LG TV with Sky remote are:
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
1*Select any channel on the TV.
2*Point your Sky+ remote control away from the TV and press the tv button.
3*Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
5. Point the Sky+ remote control at the TV and try the volume button. If this works try the other TV functions.
Please note:- in der to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Jul 16, 2011 | Televison & Video
The inlaws pushed about every freaken button on the remote,now the picture on our tv is way too big ,and the heads and logs etc are no longer there help !!! please
This formatting issue can commonly be corrected by simply pressing the (*) button on your remote this button is also known as the format button and is located in the bottom left corner of the remote, which is also to the left of the zero button. You can change the formatting of the tv picture by pressing the star/format button until the format is corrected. I hope this helps!
-Kirstie DISH Network
Jan 30, 2011 | DISH Network IR Remote Control
How do i adjust the picture to fit the screen?
The wide button on your remote adjusts the picture size. Each time you press it you adjust the picture. If repeatedly pressing the wide button is not changing the picture size check you cable/satellite remote control. Look for the hdzoom# button. There may also be an aspect or format button. When you adjust this the picture size changes and between the Sony remote and the cable/satellite remote you should be able to come to a happy medium. If the picture size still isn't changing you might not be set to the correct resolution i.e. 1080i on your cable/satellite box. It might be set too low or you might be in the wrong input (av 1 av 2 hdmi 1 hdmi 2) etc.
Jul 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
