Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
New Flyback old one wont come out
I have a RCA HD52w59. and i am trying to repalce the flyback. I read in that new flybacks come with second annode attatched so wires do not come out of old unit. What are second annode ??? and how do i replace it ???
    Problem Solver:
  • 18 Answers
If you dont know what the second anode is you should not be working on this set. on some the lead comes out of the flyback some it has to be removed from the hv distributer block. output transistor probably bad also......
Posted on Feb 25, 2009
RCA HD52W59 flyback transformer
your model uses the 270125 flyback if both wires are red. If one is red and the other black then you have the 259296 flyback.
Mar 21, 2010 | RCA HD52W59 HDTV Projection Television
Wont turn on after replacing FL231 fuse on a RCA HD52W59
If you replaced the fuse alone without installing the other components that are rquired to repair that issue the new fuse can allow voltages to flow trough the diode in both directions which can prevent the set from firing up. You need to replace the FL231, DL231 and CL230 as a set then reflow the solder on the flyback and vertical IC.
Dec 04, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Power button lights three times when pushed and unit makes squealing noise each of the three times the light comes on then nothing. No power, no light, etc...
replace the flyback which is the 270125 flyback. You can get the 270125 Flyback repair kit at the following link which contains the flyback plus detailed instructions on CD
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA HD52W59 HDTV Projection Television
Replacing the flyback
If your model is a HD52W59 the wires are part of the new transformer and have to be changed at the tripler and screen control block
Jan 21, 2009 | RCA HD52W59 HDTV Projection Television
Replaced flyback
often the old flyback will cause CP150 and CP120 to dome on top when the old flyback goes out. Check the tops of those two capacitors for doming. They are located on the same board as the flyback.
Dec 27, 2008 | RCA HD52W59 HDTV Projection Television
I am replacing the flyback transformer
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Oct 27, 2008 | RCA HD52W59 HDTV Projection Television
Flyback wires
DEPENDING ON WHICH FLY BACK YOU GET. THE ONE I GOT DID NOT. I'M LOOKING FOR THE WIRE NOW.
Oct 21, 2008 | RCA D52W19 52" Rear Projection Television
RCA HD52W59 HDTV
No the flyback doesnt have charge in it, you will need to desolder the olf flyback to remove it. I will post that link again as maybe I spelled it wrong before, cuase I just checked it and its working fine.
http://servicemanuals.vstore.ca/
Sep 05, 2008 | RCA HD52W59 HDTV Projection Television
Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
Oct 12, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
