Question about Radio Communications
Interference in our wireless intercom
The intercom has worked well for several years while we used wired DSL internet service. Recently we instlled a wireless router for connection to a laptop and a new printer/copier/scanner/fax. The home station for the intercom sits beside the laptop. Now we have interference in the intercom transmnission. What do you recommend?
  • 89 Answers
Wireless routers operate on 2.4GHz frequency. It's very possible that your intercom is in the same frequency range causing inerference. Try and find the frequency your intercoms operate on. If you can't find it on the unit, search the internet for the name brand and maybe you will find the info. If this is that case, (as I suspect it is), the only alternative I can suggest is to change your intercoms. Be sure to check the frequency of the new intercoms before purchasing. Anything but 2.4GHZ should work fine.
Posted on Feb 26, 2009
New issue after a few years of good service, very heavy static on all phones in the system. It is not the DSL filter, as i tried a new one.
Is it possible that the DSL line is filtered outside or the phone jack is defective? Has anything changed recently? Try isolating the DECT 6.0 phone system. Otherwise, consider replacing it with a 5.8 GHz system. I have a the same system (the Panasonic KX-TGA402N -- the three pack, a old 900 MHz cordless answering phone, several Bluetooth devices, and a 2.4 GHz wireless router (Linksys WRT54G2.) I have no noise problem. If you can't determine the source of the interference, I assume you already replaced the phone system.
Mar 08, 2015 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
Novi doorbell intercom system won't work. Got it about 8 years ago, worked OK except for minor problems until recently. Now it malfunctions constantly. We finally had to disconnect the wiring o
If you are looking for new intercom system then I would suggest you to buy it from http://www.hulksecurity.com/ .Hulk Security System not only provides intercom systems but they also offer variety of access control system, CCTV and alarm systems. Well, I hope this would help you and have sorted the concern for intercom system.
Oct 24, 2012 | Novi Wireless Doorbell Intercom Security...
My WRT54GC router suddenly stop passing internet through it after 4 years of uninteruped service. But all the LED s are on as they should be. I can not get either wired (my desk top) or wireless (lap top)...
Has your modem been hard reset recently? if so, it may require that you bridge the modem out to work with the router- ESP. if you use Verizon DSL. If so, contact your ISP, and ask for assistance in bridging out the modem.
Oct 03, 2010 | Linksys WRT54GC Compact Wireless-G...
Intermittent DSL connection. Frequent need to reboot modem.
the modem is already old and obselete try to upgrade the modem. even though the lights on your modem works. try to call ATT because they can run a line test so they can determine if the connection is good or not
May 22, 2010 | Efficient Networks SpeedStream 5360...
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I HAVE A WRT54G. I AM DROPPING MY WILDBLUE SATELLITE INTERNET SERVICE BECAUSE MY DIAUP IS FASTER AND MUCH CHEAPER. I WANT TO RUN THE NEW PHONE LINE TO A PC WHICH HAS A PHONE MODEM AND AN ETHERNET PORT. CAN...
The answer that he gave you is not accurate. In fact you can use your wireless over dial-up. This however takes a little work. You will need to setup internet connection sharing on your desktop with the modem. If you can get the sharing working, then you can use your ethernet card on your PC to transfer the internet back to your wireless router.
This will work, it has been a few years since I have done it, but I used it this way for several years.
Feb 01, 2010 | Linksys Wireless-G WRT54G Router
Presario 900 laptop what internet dongle do i need to connect to internet.
that completely depends on what kind of internet service you have.
The laptop has a Ethernet connector so, if you have a internet connection in your home you should be able to connect it with a wire to the router or the modem and it should work.
Sep 11, 2009 | HP 285527-001 - Compaq Presario...
I have tons of static on my cordless and i never have had this problem till today what can i do to get it resolved ? it's about 2 yrs old
Have you made any changes to your computer setup, like adding wireless internet or router? Have you added DSL internet to your phone service? Have you recently moved the phone base from one phone jack to another?
Have you started using any other electrical / electronic devices for the first time? Even an electric heating pad can cause interference. Try unplugging new or recently-used appliances. Also try going to different rooms of your house to see if there's any difference.
Mar 20, 2008 | Lands Phones
Router not working unless
Several questions --
How is this wired?
Comming from the Cable (tv) or a phone wire (DSL) from a phone jack you are connected to a modem/whatever supplied by your service provider. Then an ethernet cable (looks like a fat phone cable with extra wide connectors (8 metal connectors instead of 2 or 4) connects the modem/whatever to your router's WAN port (the separate port not one of the block of 4) and another ethernet cable connects the one of the outer's Lan ports (probably block of 4) to the desktop computer and your laptop operates wirelessly. Is this correct? If not explain houw this is wired, please. For consistency please start at the cable or phone wire.
Does your desktop do anything to log into the internet with a userid and password maybe?
If so who is your internet service provider?
We may need to change the login process and get it into the router and off the desktop.
Jan 02, 2008 | Belkin (F5D8231-4) Wireless Router...
D-Link adls modem - interference with telephone
Yea this type of happen with most of DSL users! This is due to weak signal telephone line. You should only have 1 phone and 1 internet connection. You should remove all other telephones in the home. Then it will work fine. If you only have 1 phone then you must call the phone service person who will check that status of your wire. Might be your wire is old so it creates a problem. Then replace it the you'r done.
Dec 11, 2007 | D-Link DFM 562E (dfm-562e) Modem
Radio Communications Logo
230 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
