Question about Proscan PS35660 TV
When i turn it on it goes fft fft fft then shut off
53 inch ps50670
  • Proscan Master
  • 19,396 Answers
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer..
Posted on Apr 17, 2009
I have a 2000 Sony 53 inch projection tv that turns on but there is no picture.You can see the video display but is scrambled.
It could be an issue with yoru DMD board, which are micromirrors, those are the ones that form the image. discountdashmerchantdotcom
Jul 30, 2009 | Sony Televison & Video
I have a 53 inch rear projection tv mine also shuts off right after i turn it on
Probably the Power supply/Deflection bd has a short and needs to be replaced.
Jul 15, 2009 | Samsung HC-P4752W 47" Rear Projection...
Problem of frequently shutdown unexpectedly for m6810 laptop ........When fan starts after some temp. goes up to 53 C. it causes....
laptops/notebooks tend to overheat more quickly the desktop resulting in shut down, try a laptop/notebook cooling fan
Feb 27, 2009 | E-Machines M6810 Notebook
Tv. turns off in about half hour
replace U14701-6 and U14701 IC'c
per Ttomson tech suport.
Jan 12, 2009 | Proscan PS50670 50" Rear Projection...
Tv won't turn on..
need to replace the power supply
Sep 03, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Input feed problem
I would suggest using the AV inputs instead of the coaxial input. It looks like there might be a tuner intermittent failure but using the AV inputs bypasses the tuner.
Good Luck.
Jul 21, 2008 | Proscan PS50670 50" Rear Projection...
Big screen troubles....
It is either going to be a shorted blue CRT (picture tube) or a driver board for it. I suspect the CRT itself.
Apr 17, 2007 | Sony KP-53S35 53" Rear Projection...
Scrolling lines in the picture
The capacitors in the sweep supply and maybe in the main power supply are starting to dry up. Your going to need to get a tech to go over the boards and search out the dryed capacitors. It will take some time and maybe a bit costly. May want to think maybe about a new set? Good Luck
Aug 14, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
669 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
