Question about HP Photosmart 3310 Printer
Color is off (HP Offjet 6210)How to turn it back on?
I initially turned off the color portion, to save ink. Now I can't remember how I did it, nor how to get it back on. I now need to print in color so Help. Can't find anything in the manual.
  • 268 Answers
You can simply goto
"Start" >> "Control Panel" >> "Printer & Faxes"
You will then see a list of your installed printers, right click on the one you want to change back to color and select "properties".
On the bottom of the box there will be a button that says "Printing Prefrences", select that and you will see a button to switch it to color
Posted on Feb 24, 2009
My printer is a HP- 6210, Message: "remove and
Hello Cliff, welcome to FixYa.
Hard Reset the printer by doing the following:
  • Remove all the ink cartridges.
  • While the printer in ON, unplugged the power cable from the power source.
  • Disconnect the USB cable at the back of the printer (if your printer is connected through a USB cable)
  • Restart your computer.
  • Connect back the USB cable.
  • Plug the power cable to its power source.
  • Turn ON the printer if it does not turn ON automatically.
  • Install the ink cartridges.
  • If the printer prompts for an print head alignment, please do so.
If the problem persists, replace the ink cartridge. The cartridge might be defective since you already have tried to clean the contacts.
Keep me posted.
Sep 28, 2011 | HP Photosmart 2610 All-In-One InkJet...
My HP all-in-one 6210 doesn't print in color anymore. What can I do? Thanks!! :)
Your ink cartridge ran out of color ink. That kind of brand usually has a BLACK ink and a TRI COLOR ink cartridge. You can find them at most stores , WalMart , Target , Best Buy. Make sure you know the brand name and model when shopping for them.
Nov 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can the ink cartridge HP 98 work on a 6210 HP Office jet?
No, it can't
The HP OfficeJet 6210 works with the following print cartridges:
Black: 94
Color: 95, 97
Photo: 99
Feb 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 All-in-One: Black Ink Copy Problem
i've fixed a simular issue recently, it could be your print head has developed a issue\blockage for the nossles for the black ink tank, it could be mixing colours from word but a black white copy will just use the black ink, try removing the head and using isopropol on a qtip to clean the head for the black only.......
Aug 13, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Trying to put back in the color ink cartridge for 6210
The printers are bad about damaging the ribbon cable inside the print cartridge when you replace the ink cartridge. There is a small wire spring that gets pushed through the cable rendering the printer useless. Poor design by HP. How do I know? I did it to mine. It's cheaper to buy a new one then to have it repaired.
Jul 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
New color ink cartidge won't work
Did you remove the tape on the bottom of the cartridge before you installed it?
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My Hp 6210 has error please remove and check color cartridge
that means the color cartridge is running out of ink, buy a new one.
Apr 18, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printer won't let me do anything
Must have ink in both balck AND color cartridge for the 6210 to function. Period. No way around this, as designed by HP.
Feb 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printer cartridges
Dispose of the leaky cartridge. Clean the contacts in the machine with a little rubing alcohol and a q tip (don't soak it-just moistened it a bit) Make sure the Printer is turned off while you are doing this. While you are doing this I will look up your cartridges and what they are for. I suspect that you have a color cartridge/a regular black cartridge/ and a black printing only cartride but I will check. Don't ever use a leaking cartridge they can damage your printer.
Aug 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart 3310 Printer Logo
Ben Johnson
