I also have a 2004 GMC XUV. My gate would go down but not swing open. In trying to fix it, the gate then refused to go to the flat position.I have removed the cover plate on the gate and found the one of the solenoids loose from its mounting. Resetting the computer by disconnecting both battery leads and holding them together for ten seconds worked to restore function to the gate going flat, but the swing still does not work. I believe it is a bad solenoid or motor for the bottem left latch pin.
I fixed both switches on my 2004 XUV. If you unscrew them from the back and take the switch itself apart you will probably find some corrosion on the one wire inside. I cleaned it up and added a drop of solder to make the connection. Both switches had the same problem and now both work fine.
do you mean latches or pressure switches??
I also have a latching problem with my 04 Envoy XUV and have replaced the left two latches several times. (The right one has never failed). The tailgate won't either latch closed or won't open one way or the other or both. I determine which latch is not catching and replace that one. Each time it fixes all latching problems for a few months but one or the other always fail again. I have been told GMC's latches are defectine and nothing can be done about it. So I just keep replacing latches. Just take off the plastic tailgate interior panel and unbolt the three bolts holding the latch. Unplug the electrical connection and replace the latch with the new one. Unfortunately, I'm getting real fast at doing it.
SOURCE: 2004 envoy xuv tailgate problems
I do not have the XUV model but I know that my Envoy has an electronic sounding latch lock when I close my tailgate. I would check the fuses and electrical connections. I hope that this helps.
I have a 2004 Envoy XUV. Sometime the back window will open so I can open the tailgate and sometime in willnot. I hear the motor running but it will not open the window. Other times it works. Whats the deal.
I'm having the same problem...my glass will lower but the tailgate wont open either way. I can hear it clicking when I try from the middle but nothing when I try to swing it open from the driver's side. Someone please help!
I have an 2004 Envoy Xuv and the tailgate will open like a pickup but wont swing open anymore...Why is that? can someone give me a possible answer?
2004 GMC Envoy XUV tailgate will not open, swing or drop.
I have the same problem. I have an 2005 Envoy XUV and the rear glass goes down but the door will not open flat. Sometimes the door will swing open and other times it will not open at all.
