Question about Whirlpool LER4634J Electric Dryer
Dryer will not start
Ok I have a bit of smarts but this has got me stumped. I have a whirlpool dryer that was given to me for free. When the other person had it the unit was working. I had to change the power cable since my outlet would not acept the cord and all went well. I have 242V across the outside terms. I check the resistance on the thermal fuse (.02) so that is ok.
The thing that bothers me is the timer will not even run when plugged in. What about checking the door switch? What terminals do I probe to check continuity?
Help and any other suggestions.
I did check the door switch and it is ok (open circuit when door open, .07when door closed, but I found something interesting with the voltage lines on back.
Red to Black = 242V
Black to Neutral 59.5V
Red to Neutral= 182V
Just on a whim I flipped the wires the only one that changed was Black to Neutral = 51.7V
According to the wiring schematic with the dryer Black to Neutral (cabinet) sb 120V
Hope this helps.
  • Anonymous Mar 04, 2009
    The dryer was working for straight eight months; now, it won't start.The door light does not even come when the door is ajar.
  • 630 Answers
Go to the breaker panel and make sure the neutral is making good contact. Especially check for corrosion. If it is good there, look for other connections between breaker panel and dryer. It seem to me you have a bad neutral somewhere.
Posted on Mar 28, 2009
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Dryer won't start, been using all day no problems. Go to load another load in, it lights up when I press start all I hear is a 'click' sound and then nothing. All lights stay on just like it's ready to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 03, 2011 | Whirlpool GGW9250PL Gas Dryer
I have a gas dryer by whirlpool mod. #LG7681XSW2 it has stopped and will not start and i checker the electricity and is ok.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 25, 2010 | Whirlpool Dryers
Dryer not running - turned timer & pused start & nothing - breaker ok - cord and outlet ok
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 16, 2010 | Whirlpool LER8648P Electric Dryer
Will not start
after sezerl loads, the dryer will not start. belt is ok
May 15, 2010 | Whirlpool GEQ9800P Electric Dryer
Whirlpool dryer will not start even after changing the motor
If you do not have a meter to trouble shoot with you can bypass the switch by taking off the wires and clipping them together . UNPLUG the cord first. Make sure they are not touching anything and plug it in and shut the door. If it starts it is the door switch. If it does not you have some investigating to do.
Eric
Jun 19, 2009 | Dryers
Maytag dryer stated when i push start button, then stop aft 10 mi
Hi, OK let me help. Do you hear any noise coming from the timer?
Whe it quit the first time, did it start right away or did you have to wait for a bit to restart it?
Vic
May 30, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
Mar 11, 2009 | Whirlpool LER5636P Electric Dryer
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
222 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
