I have a new Olympus E-510 that vibrates when the camera is turned off. This only seems to happen when one of the image stabilization modes is on. Is this normal??
I guess the solution to my E510 pop up flash creating a shadow when my 9-18mm lens is on, is to use...
(More)
I guess the solution to my E510 pop up flash creating a shadow when my 9-18mm lens is on, is to use the external flash. Too bad Olympus didn't think of this earlier. Any other thoughts?
olympus e-510 software freezes after a few shots and the is locked. needs to shut it off or in some...
(More)
olympus e-510 software freezes after a few shots and the is locked. needs to shut it off or in some cases take out the battery to have it unlocked and to be able to take a few shots again
the on off switch doesn't always work. you have to fiddle with it to get it to work. and if you turn...
(More)
the on off switch doesn't always work. you have to fiddle with it to get it to work. and if you turn the mode wheel or just tape the wheel gently it switch off again. is there a solution?
Olympus e510 Appears to be similar to some below. Recently autofocus, and shutter do not clode in...
(More)
Olympus e510 Appears to be similar to some below. Recently autofocus, and shutter do not clode in P, S or A modes, although the camera functions as normal in Auto or the pre-configured scene modes. Any ideas?
