Question about Dishwashers
CANDY Dishwasher CD1012 - not heating, not completing programme
Our Candy CD1012 built-in dishwasher has suddenly started not completing the cycle and does not seem to be heating up beyone lukewarm. When it stops the cycle the dishwasher has drained, but it does not seem to be hot, nor has it cleaned particularly well (perhaps due to water temperature) and I'm not sure that it has completed a full rinse. The main noticeable problem though seems to be the temperature.
  • assad hamid Dec 18, 2011
    My Candy CD1012 dishwasher gets stuck in a cycle, when setting the cycle the light is continuously on but when the cycle starts and the water comes in the light keeps fluctuating and so does the cycle so kind of on and off and carries on like this until the main switch is turned of or the front door is opened. Can anyone tell me what the problem could be ?
catriver
  • 878 Answers
SOURCE: Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Posted on Jan 27, 2007
jsrock516
  • 5911 Answers
SOURCE: Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Posted on Jun 05, 2007
  • 641 Answers
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Posted on Jul 27, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
elhomspam
  • 58 Answers
SOURCE: Whirlpool Dishwasher DU850DWGX1 won't completely drain
Commonly this is result of low water pressure or hose height/length
As long as the water is below the heating element and the dishes are getting clean its actually normal. Sometimes the pressure or hose length/height meets specs but will not always drain all water.
But as long as it is below the heating element this is normal
I am sure.
Posted on May 02, 2008
Water doesn't heat up and cycle seems to be stuck, candy DFI 45
What is a Candy brand dishwasher? Made in the UK? That is not a manufacturer I have ever heard of here in the US.
What do you mean, 'doesn't seem to heat up any sense?'
If the dishwasher is older than 5 years, write it off to age a buy a new, high quality machine. Or do the dishes by hand.
Machines get old and die. If you are UK native, don't buy anothre Candy.
Aug 19, 2014 | Candy DFI Plan Built-In Dishwasher
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
Candy DWI 160 dishwasher water not heating.
the only things is the TIMER: CAN BE FAULTY, maybe is stuck, not completely the cycle.
Clean the contact with special spray, loose the wires, replace burn wires, or break wires.
May 08, 2012 | Candy Dishwashers
Candy CD1012 fitted new console washers ok but does not do final empty I have to switch off machine and switch on again shut door then it drsins off completly
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 18, 2011 | Candy Dishwashers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
1)My Candy DFI 50 is not washing properly, it leaves residue on the pots. 2)The programme controller on my DFI 50 seems to be sticking. Sometimes the dial doesn't move at all or takes 'hours' to run a...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Aug 09, 2010 | Candy DFI Plan Built-In Dishwasher
Dishwasher starts but never seems to come out of wash cycle
Check to see if the unit is heating. Open the door mid cycle. If the unit doesn't heat then the unit cannot advance to the next step in the programme. it is basically waiting to reach temperature which it won't if the heating element or thermostat has blown. Hope this helps.
Jan 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Washer keeps stopping mid cycle
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Feb 08, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
Dishwashers Logo
337 people viewed this question
Top Dishwashers Experts
