Question about Panasonic CQ-C5400N CD Player
Aux function the head unit comes up with an AUX function but i cannot find the input??is there an input and if so where can i find it please? this is for the Panasonic CQ-C5400 W MOSFET
  • 4 Answers
SOURCE: panasonic cdplayer Model CQ-C5310U
Yes the hook is the round port on the top right side of the back of the unit right above the main hook ins for power, ground, and speakers.
Posted on May 21, 2008
  • 3 Answers
SOURCE: unable to select auxillary input
its xm ready shouldnt need to use rcazzz
Posted on Mar 31, 2009
Murphybanton
  • 2004 Answers
SOURCE: panasonic CQ-C7301U reads cds but no sound
Ensure that the rf cables are well fitted. You may swap if you are not sure.
rate this
Posted on Apr 05, 2009
  • 3 Answers
SOURCE: Where is the AUX input on this player?
Sorry, but the RCA jacks for Aux input are only available in the back of the player. If possible, you could try to attach RCA jumpers to the jacks without removing the unit, but as I have no idea of the vehicle involved, I can't say if that would be possible. IF you have the "Release" keys, sliding the chassis out should not be a problem. Slide out, attach jumpers, and slide back in after routing the jumper cable(s). (This also assumes the unit was slid in using the standard slide in and lock mounting.)
Hope that isn't all bad news. Good Luck.
Posted on Jun 14, 2009
smarthome2
  • 1114 Answers
SOURCE: using an ipod with CQ-DFX403U
http://www2.panasonic.com/consumer-electronics/support/CD/model.CQ-DFX403U
This is the link to your units pdf manual. It also covers a 7 series model which does have "Aux in" Your unit does not. You do have the capability to add a cd changer via the link on the back of the deck but it is Not an auxillary input. Now, it is correct that you could use a FM modulator running thru the tuner on 87.1 or 89.1. I think the confusion on this unit was a quick glance at the manual. It does have an "audio in" but it is specific to the panasonic disc changer and triggered thru the changer din cord. which is why you see no "Aux" on the display nor hear any audio. If you look at page 5 in the pdf version of the manual it states that the 403 does "Not" have aux in. The manual reads tricky on the other pages, sounding and looking like they are detailing the 403 when in fact the example is the 783. At the moment I can't think of a "good fix" for this pickle. I'll noodle it thru and if I can get you a solid way to make this do what you wish without lots of signal loss I'll post another comment. Hope this helps explain what's happened.
Posted on Jun 24, 2009
Aux feature
After looking your unit's info up, I found it doesn't have a built-in aux input. This was an option (not surprising seeing as it's an old Walmart version of a nicer head unit by jvc). IF the previous owner chose to add the optional aux input, there will be a black wire coming from the back of the unit that's way thicker than the rest. Follow it and it should lead you to where the previous owner mounted the aux input Jack. If there is no wire, you're pretty much screwed, because the model has been discontinued and it'll be just about impossible to find the appropriate accessory. The good news in all of that is, for the price you'd pay for the aux input alone, you can find a decent NEW head unit WITH an aux jack for the same price or darn close. Best of luck!
Jan 24, 2014 | JVC KD-HDW10 Car CD/ MP3 Player
No sound through AUX out
the aux output is for an mp3 player or ipod. Does the HU have preamp outputs? The RCAs from the amp should go into them. If it doesn't you might have to get a high to low level input converter
Mar 28, 2010 | XO Vision XO9013 Car DVD Player
I have a Kenwood KDC-MP235 installed now and bought a cable to run from my MP3 player into the aux input on the front of the unit but I can not get it to play or find an aux input switch anywhere on the...
hey dear, just do this if you wanna set AUX function: turn off your head unit.. when is in standby mode, press the volume knob and hold it pressed until it appears some words... then start moving on to differente options by clicking left-right of the right knob... you will find aux on-off
not sure if standby mode, or completely turned off (to turn it off just click the SRC mode a few seconds)
Sep 29, 2009 | Kenwood KDC-MP235 CD Player
Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
hope this helps
Aug 26, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
Aux Jack
first off you need to make sure that the factiry head unit has a aux drive or if the aftermarket has one as well if it does just set head unit to aux plug it in and play music if it doesnt you will need a new head unit that has aux input. if your car has one it could be on the radio face or the back could be very difficult to pull the radio refer to your manual on how to do that
Jan 02, 2009 | Car Audio & Video
Ipod worked with my pioneer deh-p3700mp before
this works on some other pioneer head units i encountered it may work on yours.
Shut it off and hold the function button until the options appear then you can scroll through and change a bunch of settings including the aux input
Dec 31, 2008 | Pioneer DEH-P3700MP CD Player
How do i get to the AUX setting
Dec 29, 2008 | Pioneer DEH-P6800MP CD Player
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
How do I turn on the "external aux" for my pioneer DEH-p7000r
You'll need an adapter cable such as this one:
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=ip+bus&i=469PIOPRCA
The adapter cable will convert the changer port on your head unit into an AUX input with dual RCA jacks. Once connected, the head unit will detect the cable and allow it to be another source (i.e. radio, cd, aux).
To connect your iPod to the adapter cable, use any iPod cable or dock that outputs to male RCA plugs.
Apr 01, 2008 | Pioneer DEH-P7000r
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Panasonic CQ-C5400N CD Player Logo
61 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
