Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
RE: DYSON DC07. Cleaning the roller I removed one end and cleaned it. Cannot get the roller back on the vaccum. If you could give me instructions on how to do this I would be very appreciated. Thank You
  • Anonymous May 12, 2009
    I also took the roller off of the vacuum and now I cannot get the roller back onto the machine. I don't want to force it as I am afraid that I will break the plastic.
    Problem Solver:
  • 13 Answers
Try this link. http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/dyson-dc07-technical-advice-459/dyson-dc07-changing-the-clutch.html
You have to slide the belt first. Make sure that the rounded edges of the brush assembly align properly.
Posted on Sep 27, 2009
How do you clean the brush roller on a dyson vacuum
For a step-by-step guide on cleaning your DC07's brushbar, please visit our Support page::
http://www.dyson.co.uk/support/dc07/dc07-all-floors/maintaining-your-dyson-machine/how-to-remove-a-blockage/soleplate-removal
I hope this helps. If you have any further questions on using or maintaining your machine, please visit www.dyson.com and click 'Support', or give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 14, 2012 | Dyson DC07 All Floors Bagless Upright...
Where do I find instructions to replace the roller brush on my DC07 Animal
VacuumGuru here. I have made a video on how to check your clutch and brush roller.
Please take the time to rate the solution or give me a thumbs up.
If you need to buy filters or belts for your Dyson DC07 I would go to Vacuumspot.com.au or NelsonVacuums.com.au
Hope this helps :)
Oct 16, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Rollers stopped turning. i removed and cleaned them but won;t turn. suction there
Did you check the belt? Here is a link for the instructions on how to change the belt and a link for the belt you need:
DC07 Belt Changing Instructions
Replacement belts for DC07
Nov 19, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Roller bar (barush bar) does not turn
u may be able to turn it by hand, but stuff "hair" is not letting it turn like it should. this unit comes apart vary easily. clean the ends of the brush bar and the housing where it sets, after it is removed. u will see that it should free spin.
Oct 02, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
DC07 Low Reach Vacuum smells like a belt is burning and is making
The roller is likely jammed, or there is debris around the belt area
Jul 05, 2009 | Dyson DC07 Low Reach Bagless Upright...
Dyson make noise after replacing brushroll
Try this open sole plate check make sure belt is not pinched, broken or binding, that thee are no strings or hair between belt & roller,& that belt it is centered on roller.
Be careful & turn roller by hand should torn smoothly except for belt tension.
Also check make sure end bearings are seated correctly. (the parts at the end of the roller where they go into housing.)
Hope this helped. Please rate. If you need more help comment back be happy to assist you further.
Mar 14, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
LOUD GRINDING NOISE ALL OF A SUDDEN , LOOSE BELT ?
you will probably have a faulty roller bar take of panel on bottom of vaccum. Now remove the roller bar hold the bar by both ends and try spinning. This should be easy and smooth if not pull off the end cap these will be very tight and check the bearings in each end i think you will find a few small metal balls rolling around inside if this is the case you need to replace the bar
Nov 06, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/
Jun 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
239 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
