Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
My lights are off in the subzero 650.
Breaker is OK. I can hear engine humming. Lights are off in fridge and control panel.
  • 71 Answers
Replace light bulbs or light switch...... is cooling ok?
Posted on Apr 02, 2010
The light in the refrigerator went out and now it is beeping when we open it..we got an estimate of $130 to repair....we wanted to see if we could possibly do it ourselves?
Dear ssala19,
I'm sorry to hear that the lights in your Sub-zero unit are not working. It is unlikely that all the bulbs went out at the same time. You most likely have a bad light switch. If you open the refrigerator door & look upwards you will see two white switches. The switch on the left controls the lights. The part number to this light switch is 7014646. We can supply you with light switch replacement instructions if you contact us directly. Make sure that you turn the unit off at the circuit breaker before changing the light switch.
To find a Factory Authorized Service Company in your area please use the link below. Enter your zip code, select 'Service, Repair and Parts', choose a mileage radius, and you will receive a listing of all Factory Authorized Service Companies that meet your requirements. A Regional Parts Distributor can also be found via this link if you would like to order the switch or bulbs.
http://www.subzero.com/locator
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Feb 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Jun 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
The temperature controls for the refrigerator are not responding. The freezer controls respond just fine. My fridge is set to 34 and I need to get it back to 37 but it won't change the numbers.
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 14, 2009 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650 not running
Check the light switch on the door frame, if that doesn't do the trick change the light bulb. If your refrigerator is not running and cooling and the light is out check the power, plug & circuit breaker in the power center.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Mar 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero door left open - now acting strange
You have probably already figured this out, but if the door is left open there is a sensor that will turn the lights off to keep the fridge from overheating. After you close the door and let it sit with the lights off for 15 minutes or so, the sensor will cool and allow the lights back on. If the temperature reading in the window is ok and does not say "service" or "vacuum condenser", then you should have no more trouble.
May 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
468 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
