Question about Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver
Won't charge i have had more problems with this phone than all my phones combined in 10 yrs. Somehow i have been able to overcome alot of these problems on my own but i swear this phone has a mind of it's own. this is the most money i have ever paid for a phone and it's worthless. now my phone won't charge at all. at first i couldn't even get it to read the charger but now it finally shows the icon by the battery symbol that shows the plug but after all day of being on the charger, it is still at 0%...what in the world should i do?
  • 21 Answers
Your phone could be water damaged it could be moistered open the back take the battery out there is a white sticker if you see it red or any other color that means your phone is water dammaged if that s not the case the battery could be the problem
also some times if the phone is flushed it loses charge fast
Posted on Jun 06, 2009
I phone problem
Hi sir, have you tried using another cable coz i can see from the video that it already has a scotch tape in it so maybe that's the reason why the phone is not holding a charge. Try also plugging it in a different computer or a different wall socket. Also, you may try hard reset by pressing home and sleep button for 10 seconds
Jul 05, 2013 | Lands Phones
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
Nokia 2700c battery low problem
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 04, 2012 | Nokia Classic 2700 Cell Phone
My pantech laser won't charge what's wrong
if you move the cable around just right will it charge?
if not u could have some kind of damage. did you drop it
i would just try buying a new battery on ebay they are usually pretty cheap online.
if you charge your phone alot and overnight. thats really bad for the battery
Sep 26, 2011 | AT&T Cell Phones
My phone won't charge and is about to die. When I put it on the charge is says "Unable to charge. Non supported battery." I've tried using the air in a can stuff on the ports but that...
You may have a hardware problem. It's very common for the charging port in a cell phone to become damaged somehow, which can cause this error. Other possibilities is a damaged battery or damaged power cord. Your best bet is to bring the phone to your carrier's nearest store and have them check it out for you. If it's the battery or the cord, a simple replacement is cheap and quick, but if there's a problem with the phone itself, you'll need to get a new one.
Jun 10, 2011 | Samsung Glyde SCH-u940 Cellular Phone
Somebody changed my phone lock code and I can't use anything in my mobile now without entering the phone unlock code which give space for 8 digits only.
There is usually a default code to get into your phone try all 0's. If that doesn't work try a battery pull and then try your previous combination or 0's again.
Feb 28, 2011 | Cell Phones
Battery easily drained
try reflashing the phone or also take off the bluetooth if it is on the phone
Sep 02, 2008 | Sony Ericsson W910i Cellular Phone
Motorola L6 Phone not charging or working
Well,
I solved the problem for my L6. IT appears that somehow the phone is software dependent. Meaning that you need to have the Motorola Software for the phone installed in your computer, connect the phone and voila! At least it solved my problem. All of a sudden it charged automatically and I can now charge with the power adapters too. (Yes I too went and bought a different charger, then when it didn;t worked I got a different battery..etc.) just give it a try. I think you can get it for free online somehow, just google it.
Jul 09, 2008 | Motorola Mobility L6 Cellular Phone
Unable to charge
Same problem here but phone is 14 mo old. Just stopped charging even though it says it is. Got new battery, same thing. Charged battery in different phone and was fine. swapped and it works. so... phone is bad somehow.
Apr 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver Logo
37 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
