Question about Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference
Polycom Soundstation 2W - Dials Number, Connetcs, But no Sound
When dialing a number from my Polycom, the unit does not ring. But, the call goes thru, the person on the other end of the phone answers, but they can't here us and we can't here them. I have re-booted, set all noise levels to their highest levels, checked all microphones (they are all good), re-registered with the base station, etc. and nothing seems to work. I would appreciate any ideas that you may have.
Thanks.
  • 3 Answers
SOURCE: Polycom soundstation 2W
i saw a post say push 1, 4,and 9 it worked for me
Posted on Jan 11, 2008
SOURCE: POLYCOM SOUNDSTATION 2W
I thought well I wonder what holding down other buttons would do to get rid of this cursed PLEASE WAIT issue.
I tried * and # together and hey presto it worked.
I did however have to go in and turn IP mode off.
Posted on May 05, 2008
maklean
  • 1665 Answers
You may download the following manuals related to this product
at link below
http://safemanuals.com/user-guide-instructions-owner-manual/POLYCOM/SOUNDSTATION%202W-_E
Posted on Jun 23, 2008
brodie7838
  • 11 Answers
SOURCE: Have a Polycom Soundstation 2W that is stuck with
Hi Tina,
You should be able to enter the menu of the phone to re-register it to the basestation. If you are having difficulty getting it to register, I'd recommend using a Mini USB cable to update the software of the phone. If you are still having problems, give support a call: 800 765-9266 (8:00am to 9:00pm EDT, Monday to Friday)
Posted on Feb 26, 2010
SOURCE: how to reboot soundstation 2w polycom if you
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Posted on Apr 05, 2010
Polycom soundstation 2 does not have a dial tone
That Polycom runs off of Analog dial tone.
Either a dedicated line or in most cases from an ATA off the phone system.
You should be calling your vendor/tech in that handles the phone system to check programming, cabel, jack and the Polycom itself too.
Dec 11, 2012 | Polycom Soundstation 2 Full Duplex...
We moved our Polycom Soundstation 2 from one office to another. It was disassembled and reassembled by who knows who. It is using an analog port from an NEC DSX 80. It recognizes an incoming call, but,...
sounds like the 'brick' went bad
this is the power supply try replacing it
also and possibly more important did you reprogram phone and phone number when you moved it??
make sure you reset all settings and start new
Mar 17, 2011 | Polycom SoundStation
I can not get a dial tone on our new soundstation 2W I have unhooked one of our phone lines in our office so the line is good but does not work on the soundstation but works on our phone. When you try...
You need to update the software on the device. I called their support line and the tech explained everything. This has been a common problem with this conference phone.
Feb 07, 2011 | Polycom SoundStation 2W (2200-07800-001)...
How to reboot soundstation 2w polycom if you forgot the password
OR
1. press menu key
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
Usin for an internet conference
You need to buy a Computer Calling Kit from Polycom. That is essentially a cable with a 2.5mm connector to the Polycom Soundstation 2W on one end and two 3.5 mm connectors to the PC Sound card end (one to the Microphone port and the other to the Speakers port).
Mar 08, 2009 | Polycom SoundStation 2W (2200-07800-001)...
I went to Admn Setup to reboot the system from Please Wait.... & it doesn't work!! Best Solution posted on Sep 19, 2008 2%20stars.png
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Just had this problem with the 'please wait' - go into the admin setup and select Reboot Phone - it then works!
Jun 23, 2008 | Polycom SoundStation 2W (2200-07800-001)...
Jan 07, 2008 | Polycom SoundStation 2W (2200-07800-001)...
Polycom Sound Station
SoundStation: Changing dialing from Tone to Pulse
http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10966&sliceId=SAL_PUBLIC_1_2&dialogID=979138&stateId=0%200%20977279
Description
sp.gif sp.gif There are three ways that a SoundStation can be changed from tone to pulse, which depends on when the unit was manufactured.
1. Pressing the Keys 3&Vol + simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
2. Pressing the Keys *&MUTE simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
3. Operation done by DIP switches. Dipswitch Configuration On the bottom of the SoundStation, in the lower left hand corner of the large sticker may be a small silver sticker. Underneath that sticker are 4 DIP Switches. Switch number 4 is for tone and pulse,ON being tone, and OFF being pulse. Do not change the other three swithces as this could render the phone inoperable.
Sep 19, 2007 | NorStar Polycom Soundstation ( Phone...
Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference Logo
178 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
Sandeep Kamat
Sandeep Kamat
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
