Question about Emerson EWL20D6 Television
Emerson EWL15D6 I can't find a Dish Network remote code.
  • 362 Answers
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Let me know how it goes and please rate this solution. Lone99star
Posted on Feb 24, 2009
I need a remote code for my dish network VIP722k DVR with my sony RMVZ320 remote
Check with DiSH for a possibly unpublished code. You may find that only the DiSH remote will work.
Jan 01, 2014 | DISH Network IR Remote Control
Dish network remote control and akai tv
Not likely the Dish remote will have that remote code at all in it--some of those sets were made by Samsung so try those codes also.
Jun 01, 2012 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I need a remote control code for a emerson tv for a dish network remote. tv has built in dvd player.
Here is a list of our Emerson codes, if you still need help just let us know!
632,652,661,662,682,720,512,692,660,699,670,677,679,544,655,657,658,526,534,536,590,627,636,642,648,659,541,537,654,665,666,667,669,696.
Daniel Busa
DISH Network Customer Service
Jan 27, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I have a vcr dvd combo and i want the code for my dish network remote so i can use one remote please
We would be happy to help you with that. Here is a list ofcodes that should address your DISH Network remote to your Emerson DVD/VCR combo unit: 588, 505, 506, 518, 534, 536.
Press and hold the DVD/VCR button located on the top of the remote until allthe mode buttons at the top of the remote light up, then release. Use thenumber buttons to enter one of the codes for your Emerson DVD/VCR combo unit, thenpress the pound (#) button. If the code entered is valid for the remote, themode light flashes three times. .To check that the code works try several different functions on the remote tomake sure it will properly operate your Emerson component. Keep in mind that somecodes may not be compatible with your equipment. If this is the case, pleasetry the other codes listed for that device until you find one that iscompatible with your equipment. We hope this helps and thank you forbeing a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 20, 2011 | Emerson EWD2203 DVD Player/VCR
I am trying to find the codes for a Dish Network remote ( 6.4 IR/UHF PRO ) to program TV Emerson LC320EM1 and if possible for the Lenoxx Sound Home Theater. Thanks in advance for any help.
Hello, my name is Daniel Busa with DISH Network customer service below, are the codes for your emerson tv and a limk with instructions if the codes don't work try the powerscan method in the link I gave you.
632,516,627,654,720,532,500,526,534,536,541,573,,590,636,642,648,652
http://www.dishnetwork.com/SupportSection/setup-remote
Jan 06, 2011 | DISH Network IR Remote Control
Need remote code for a emerson lc320em1 to use my dish remote?
Hello! Daniel Busa with Dish Network customer service department here is a link for a code scan this should be easier. http://www.dishnetwork.com/SupportSection/remote-setup
Dec 25, 2010 | DISH Network IR Remote Control
I have ( Apex digital LD4688 ) I neeed the code. Thank you.
I install dish network. i have tried all versions of dish remotes, . the only one that works is Dish Network 21.0 Learning Remote. it will work with all dish products and i have programed it for this tv apex ld4688 hd and it works great.here is a link for the manual on how to use.
http://www.satelliteguys.us/dish-network-forum/158496-dish-network-21-0-learning-remote.html
Nov 27, 2010 | DISH Network IR Remote Control
Looking for a code to use on my Dish Network (Universal) remote in order to operate my Emerson Model EWD2202 Combo VCR/DVD player
Hi my nameis Mike Houston of DISH Network and I was going over your post and see whereyou want the codes to program the DISH remote to the Emerson DVD/VCR. We do nothave the three digit codes to enter however we do have what we call a PowerScan and it will allow programming the remote to the Emerson player, I willsend a link to help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Oct 31, 2010 | Emerson EWD2202 DVD Player/VCR
Remote codes to use dish network remote with emerson tv model lc320emxf
We would be happy to help you with getting your DISH Networkremote to control your TV. Pressand hold the TV button located on the top of your remote until all mode buttons at the top of the remote light up, then release. Use the number buttons to enter thecodes for your Emerson TV; here some of the codes we currently have: 764, 632, 648, 672, 654, and 516.Press the pound (#) button. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the TV. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, please try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
Jul 25, 2010 | Emerson LC320EM8 32 in. LCD TV
Emerson EWL20D6 Television Logo
167 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
