Question about Dell 3100cn Laser Printer
Dell 3100cn Smudges on all color except black
I have replaced the drum and yellow and cyan. All three colors streak when I print in those colors but black does not streak at all when I print a solid black page or use printer diagnostics. Does anyone know what this might be, and why black is printing fine?
  • cperillo Mar 02, 2009
    It does not appear to be the fuser. If I stop the printer in the middle of a job I can see the streaks are there before it gets to the fuser when the toner is still not fused to the paper. I have tried multiple applications and I have re-installed the drivers and used the printer on different machines. This is a real pickle.
  • 3 Answers
This is actually a drum issue, although changing drums doesn't always fix it. The problem is the at the tolerances between the transfer belt and the top cover of the drum is too close so the belt can scrape on the ribs inside the cover, getting a toner buildup and causing streaks in the color. Notice it is not streaking the black; this is because the black is laid on the belt last and the belt does not go around again.
This is such a flaky problem because a perfectly happy unit can suddenly start streaking because of temperature changes or, I suspect, even something as simple as moving the printer can cause things to move enough to cause the issue. A good article I have found for fixing it is at http://www.ahfx.net/weblog.php?article=133. Dell forums also discuss this issue -- it's a known issue and I think Dell should fix it.
Posted on Mar 30, 2009
  • 49 Answers
Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
Posted on Feb 27, 2009
Just wondering: my printer's yellow and black toner are both empty and need replacing. Would this cause the printer to calibrate for minutes at a time? After calibrating, I tried printing a document with...
If your going to print in color may it be just red or blue. You really need all of the cartridges for it to work. Because for the printer to come up with those colors. It would need all three colors Cyan, Magenta and Yellow to come up with the any color, in your problem, Blue and Red.
Feb 04, 2011 | Dell 3100cn Laser Printer
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
Drum kits marking up and streaking the paper
You can check with Dell to see if there is a maintenance kit for this printer. I know that there is one for the HP counterpart. You will probably need to replace the fuser, and maybe the pickups and rollers, but as I said I am not sure if Dell has a maintenance kit for these machines.
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Dell 3010cn Color Laser Printing Quality
yes..it's almost certainly the drum..did you get a new one or was it simply refurbished?
Aug 20, 2008 | Dell 3100cn Laser Printer
Dell 3100cn
I've the same problem with a 3000cn but on the black color. all other colors are great execpt the black one.
Any Ideas someone ?
Apr 02, 2008 | Dell 3100cn Laser Printer
Streaks on left side
REPLACE DRUM CARTRIDGE THE CLEANER BLADE IS BAD
Jan 20, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
653 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
