Question about Sharp Office Equipment & Supplies
CODE H2 THIS MACHINE WAS WORKING FINE, THEN ALL OF A SUDDEN THIS CODE CAME UP. IT ACTS LIKE IT'S GOING TO CLEAR, BUT IT DOESN'T
  • tonyg_7 Feb 27, 2009
    my machine is a Sharp model SF 8500 like I said this machine was working fine, and it worked fine, then I moved it from one room to another and pluged it up, and this code came on
    thank you
  • Marvin Villanueva May 11, 2010
    The problem you are encountering is in the fusing unit , the temperature is abnormal, can you please specify what is the model of your machine because there are different ways on how to cancel the trouble status.
  • 37 Answers
This model of Sharp is too old, there is a problem in the fusing unit, try these steps to cancel the trouble status:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is broken on the fusing unit like thermostat or thermistor.
Posted on Feb 28, 2009
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
I cant clear H2 problem on sharp AR-M160 copier machine
"Press # - Interrupt - C - Interrupt -14 - Start key Thermistor open
The thermistor is open. The fusing unit is not installed.
Mar 29, 2012 | Sharp AR-M160 Black and White Copier
My truck was running just fine then all of a sudden wouldnt start.. its acting like its not getting gas but its turning over, just not starting.. sounds like a fuel pump?
change the filter first,, if that doesn't work, then spray some carb cleaner into the intake, ( or throttle body , and turn it over, if it runs as long as you spray ( don't use to much) then its probably going to be your fuel pump
Sep 05, 2011 | 1994 Toyota Pickup
ERROR CODE H2,HOW TO RESET IT/TO CLEAR
Press Keys : # interupt C interupt....................... then machine will be powered off then press Keys: 1 4 Copy then H2 will be removed. By rehanjoiya74@yahoo.com
Mar 07, 2011 | Sharp AR-5320 Black and White Copier
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-M450N+ Code: H2-01
Hello sir; You may do a reset simulation; press "p" "*" "clear" "*" enter 14 press start enter 0 press start , machine will go back to working condition.
Sep 12, 2009 | Sharp Office Equipment & Supplies
Sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Jun 19, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Error code H2-00 on e studio 162d?
u have a dirty thirmistor in fusr unit.first clean it.then do this procedure.press clear key,auto photo key,clear,auto photo key in a sequence.copier will go dead .when display goes dead just press 14 start key.copier will take few second and will bi ok.by MIAN AKHLAQ
Nov 18, 2008 | Toshiba e-Studio162D Copier
Service code H2-01
Press "#" "Interrupt" "Clear" "Interrupt" then hit "14" "Start" then go to sub code "0" or it may ask to clear code.... Good Luck..
May 13, 2008 | Sharp AR-M237 Digital Copier
111 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
