Question about Video Game Consoles & Games
Ps3 i swithch it on at the back press the touch botton at the front it powers up but no sound or visual i'v try differant leads an tv's and tryed holding the front button untill it beeps to reset visual setting but still nothing. Im gathering its dun for then? its out of its waranty i did't want to send it away im farly good with a soildering iron haha. pleaese hell me Rob
    President:
  • 2,653 Answers
Check out my common PS3 problem and repair guide for tips and suggestions for your problem.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Posted on Feb 24, 2009
My tv wont connect to the ps3 with a hdmi lead
Do one thing. Connect the HDMI to TV connect the power to PS3. The press and hold the power button on the Front panel of the PS3 for 4 seconds.Then follow the instructions on the screen. While you hold down the power button PS3 will reset all the setting and will let you choose the Video resolution.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 26, 2016 | Televison & Video
I have just brought ps3 and when i plug the leads into the tv ie red white and yellow leads i can not find the channel on my tv i have tried other tvs and same thing so i done away with the lead and just...
Hi, try not using the hdmi lead and plug the other lead back into the ps3 the normal av lead with the 3 color wires, now plug it into your telly now switch the ps3 on at the back so the red light is on at the front, now hold down the one button and it will bleep once then bleep twice and keep holding it down till it switches back off
so basically you switch it on at the back then press and hold down the on button until the ps3 turns itself back off, now what this does is reset the video mode so its not set to hdmi settings, now press the on button again and wait for it to come on if you still dont have picture on the telly make sure the video lead is fitted correctly and then get the telly remote and find one of the following buttons
av
source
input
or a rectangle with an arrow facing to the right.
once you have found this button make sure the ps3 is on and then press this button on the tv remote, you may need to press it more than once depending on how many inputs the telly has on it.
now when you press the button on the tv remote press it once then wait 5 sec before pressing it again just to give it chance to pick the signal up.
hopefully now you have the ps3 working through the normal av lead
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
Hi I have playstion 3 slim and when i turn it on it powers up but there is no picture and it sounds like the machine is not working like normal like
Have you set the video mode on the machine or plugged it up to a different TV? if so try this >>>
Make sure all leads are connected to the TV.
Next, turn the PS3 off so the red light is on. Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
That should have reset the video settings so you will be able to set the video settings again and access the PS3 menu.
Post back if you get no luck.
Regards.
Jun 22, 2010 | Sony Playstation 3 (PS3) Console
I get sound but no visual output
That should have reset the video settings so you will be able to set the resolution again.
Regards.
Jul 02, 2010 | Sony Playstation 3 (PS3) Console
I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
Can not connect ps3 to tv
You might want to try this one.
Connect your PS3 to your TV with the correct leads Like you normally do.
Press and hold the power button on your PS3 for approx 5 seconds this will then bleep twice.
what you have just done is factory reset on your PS3.
What it sounds like you have done is changed the television that the PS3 was originally setup on. PS3 hold tv information on the hard drive this can lead to problem when you relocate the PS3 or get a newer/different telly.
Hope this sorts out the problem for you
Cheers Little Dish Fitter
Sep 02, 2009 | Televison & Video
No picture coming up on tv from ps3 ps3 turns on but no picture comes up on tv.. tried it on 2 tvs but same happens
ARe you getting sound?I suspect it might have flipped to hd or back to standard def, depending which setting you originally had it on Try holding down the power button when you turn it on, untiil you hear 2 beeps, this should reset the visual settings on the ps3
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
Crackling sound on PS3
the laser is starting to wear out. it cant reda the audio fast enuf to keep up with the visual side of the game resulting in crackling momentary hissing or cutting out of music
Jun 03, 2009 | Sony PlayStation® 3 (80GB) Console
No audio or visual via AV Cable
turn the power off in the back and then turn hold the power button in on the front then turn it back on in the back and continue to hold the front power button down for 5 seconds and you should here a beep then let go. Then turn it back off then on
Apr 26, 2009 | Sony Playstation 3 (PS3) Console
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
