Question about Rainbow E series Canister Wet/Dry Vacuum
"New" Rainbow Eseries flashing red light
I noticed a red flashing light inside the vacuum right under the on/off/purify control - it looks like a filter. The light only flashes red when the vacuum is on and on purifier mode.
    New Friend:
  • 27 Answers
This is fine it is an indicator light that the computer is working.
Posted on Jul 30, 2009
  • Godmonkey Nov 22, 2010
    I have the same thing accept my vacuum is broken its runs poorly for a bit then stops working...
Rainbow turns on for a second or two then quits and won't turn back on.
If you have the model Rainbow E-2 eSERIES then the Motor Rainbow 120v could be going bad. This will trip the auto reset until it cools down.
If you have an E2 Type 12 Rainbow, then the Controller Asm 120v e2 Silver Gold could be going bad.
Our technical support team is available if you need... Contact Us
RainVac
Mar 24, 2016 | Rainbow E series Canister Wet/Dry Vacuum
How do I fix dyson cordless vaccum flashing red light
Hi there, it's Jack at Dyson.
A flashing red light from a Dyson cordless vacuum signals a fault with the machine. We're happy to take you through some simple diagnostic checks over the phone when you have your machine easily to hand - just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
If a replacement part is needed we can also confirm if this is covered under your Dyson guarantee.
We'll look forward to speaking with you.
Feb 20, 2015 | Dyson Vacuums
I have a sebo x4 , when I switch it on the red lights flick on and off and nothing happenes
The red lights should flash very quickly upon vacuum start-up (normal). If the motor is not turning on there is likely a problem with the motor or power supply board. The lights flashing does indicate that you are getting power to the PC control board. If your vacuum is under warranty, this would likely be covered. I have included a link to the parts list for your reference. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Oct 05, 2014 | Sebo X4 Bagged Upright Vacuum
Armature and rainbow vacuum
The armature for the E-2 (eSERIES) model Rainbow is not available by itself. You have to purchase the Motor Rainbow 120v.
Now the new design motors are steps above the original motors so you should see improved performance as well as durability.
Our tech. team is available if needed... Contact Us
RainVac
Jun 18, 2014 | Rainbow E series Canister Wet/Dry Vacuum
When I turn on my dyson animal vacuum the red light flashes on and off and there is no suction
I think you have a blocked pipe somewhere. I use a large marble to drop through the pipes to see where the problem is.
Mar 11, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Rainbow vacuum won't power on.
Do you have it on the water pan? All models above the eSERIES will not run without the water pan.
RainVac
www.rainvac.com
800-523-0510
Jun 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Why would the motor of a Rainbow E series vacuum cleaner be made
The bearing for the single speed eSERIES is available on our website. Click here
RainVac
www.rainvac.com
800-523-0510
Mar 18, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Nikken Air Purifier, Model NKAP100: Change Filter red indicator stays lit after new filter has been installed
Under the front panel, under and to the right of the control panel is two holes, one the size of a pencil eraser and below it is one the size of a dime. In the hole (the size of a dime), is a pin hole use a paperclip and poke the hole. It will reset the filter light. We had the same problem, and couldn't find the manual. Our Nikken rep was No help either.
Apr 20, 2011 | Vacuums
Hi, My Electrolux twin clean vacuum has both red and blue lights flashing and I can not get it to turn on to clean the filters. Any suggestions
Try taking the twin filters outside - also take a dustpan brush and tap the filters gently on the bottom, then brush the dust away as it comes out. This can take quite some time, and you will find that LOTS of compacted dust will come out!
Feb 20, 2011 | Electrolux Twin Clean Bagless Canister...
Rainbow E series Canister Wet/Dry Vacuum Logo
967 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
