Question about Ideazon zboard keyboard gaming interface for Microsoft age of mythology pc game
Joystick won't work on X/Y Axis in Fighter Ace
In order to play Brothers In Arms Hell's Highway, I have to unplug my joystick. Otherwise it just spins counter-clockwise in BIAHH... so... I unplug the joystick (Logitech Extreme 3D Pro), then I go to my Zboard "configurations" and activate the Brothers In Arms configuration and play the game. Everything is great so far.
Now I decide to fly in "Fighter Ace" by Ketsujin Studios, on-line game. So, I re-set my Zboard to the normal default (as it was before playing BIAHH) and go into FA. I plug in the joystick and the "nose up/nose down axis" won't work. Everything else, all buttons, hat view button, trigger, bombs, rockets... flaps... everything works on the joystick except "nose up/down"... I don't know how I fixed it, but it was hell to do. I deleted and re-loaded the joystick software, and everything imagineable.
What does happen is when I pitch the joystick 'right to left' both the X and Y axis seem locked together... push the stick forward or pull back and the tail flaps for rise and fall don't work... only in the right to left action... again... the axis are locked together.
What's the way to leave FA, unplug the js, go to BIA on Zboard, play the game, and then go back to FA by simply plugging in the js and setting my keyboard back to default (normal mode) w/out having to go through hell and back????
Thanks,
Mike
  • boxofjuice Mar 22, 2009
    ya dude its doing that to me in cfs
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
Hi I have windows vista and im trying to play an old game called USAF 15.. The bottons will work during the game but the joystick will not controll the plane. In my control panel the joystick works fine...
Go into the settings for the game and check and make sure that the game is detecting the X and Y-axis. You might need to check enable joystick or some similar option.
Jan 30, 2010 | Logitech WingMan Extreme Digital 3D...
Blank screen on pressing play brothers in arms hell highway, Sound in background
Well your disc is officially garbage because it's scratched. Don't bother trying to fix your game disc. Do what I did. Go to sellitbroken.com and sell your game to them. They will give you good money for it.
Dec 31, 2009 | Ubi Soft Entertainment Brothers in Arms:...
Doesnt work when i push or pull on the stick
If it's anything like an authentic joystick control, there may be a switch where your fingers rest which must be gripped/engaged in order to achieve movement, but i've never actually seen this controller so I can't be certain.
Oct 04, 2009 | Guillemot ThrustMaster Top Gun AfterBurner...
My Chrysler navigation joystick is broken how can i fix it
I found a source for the sw421 joystick the only problem is i had to order 5 to meet minimum order. I successfully repaired my navigation joystick. Its a 4 axis with push toggle activated switch in the middle. If anyone would like me to repair their unit I will do 4 for $75.00 u pay shipping. It takes anout 1 1/2 hours from start to finish. So the unitcan be back in the mail to you the same day. emericktom@yahoo.com
Oct 06, 2008 | GPS
Logitech Freedom wireless joystick
i have had similar problems... it might be the disk also if the disk is really old it might not play properly becuase your computer is to new.but if that isent the problem your joy stick might only hook up to a desk top if you have considered these issues and nothng seems to effect it well ... get a joy stick that needs to be hooked up ... hope i helped
Jul 27, 2008 | Sony Logitech Freedom (vs9632830403)...
Problem with Logitech Attack3 joystick with Apache Air Assault
Have you tried going into the options menu in the game and go to the controls section at the top? You have to set all of the settings to the various joystick axis in order to make the joystick work.
Mar 23, 2008 | Video Game Consoles & Games
Why did the Y-axis stop working?
Same happened to my joystick, it happened when i put the drivers for it on, then i deleted them and it fixed it. Them the Y axis just stopped about 2 weeks later....
Mar 19, 2008 | Apple Logitech Freedom 2.4 Cordless...
X AXIS INSTABILITY
Is this an issue only with this game or other games as well?
Here are some articles from the logitech website that may be of some help...
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/
std_adp.php?p_faqid=289
and
std_adp.php?p_faqid=27
Dec 22, 2007 | Logitech Attack 3 Joystick
Ideazon zboard keyboard gaming interface for Microsoft age of mythology pc game Logo
422 people viewed this question
Top Ideazon Video Game Consoles & Games Experts
James Wishart
Are you an Ideazon Video Game Console and Game Expert? Answer questions, earn points and help others
