Question about Parsons QuickVerse 2005 Expanded Edition (11149)
I have had Quickverse 2005 for some time and used it with Microsoft word 2003. The cut and past worked fine. I have upgraded the same computer to Microsoft 2007 and, when I cut and past, the line spacing is messed up and I can't figure out how to get it back to single space. I use this process to assist in having the scripture in front of me during preaching.
    President:
  • 1,314 Answers
Thanks to the folks at Microsoft for setting that as default in 2007.
Go to the home ribbon, you should see in the heading styles, a style called normal. Right click on it and select modify.
Here you can select the defaults for the normal template which is used each time Word starts. You can choose your default font, size, etc. Underneath the font you have four sections. The first one is the justification which should usually be left justified. The 2nd one is important, this is your single-double-triple spacing icon. Select the first one. The next one after that helps to fine tune that a little bit. Click the two arrows point towards each other until the spacing doesn't get any smaller. Make sure that you select New documents based on this template, then click OK. If you have any further questions, let me know and I can assist further. Also, if you could please give this solution a rating of fixya, I'd greatly appreciate it. Thanks and God bless!
Posted on Feb 24, 2009
Quickverse 7.0 and vista
run msconfig and check if any Office programs
are running at startup uncheck them or delete the entry run from the registry ,and any Office programs that
are running during installation it exist
Dec 19, 2007 | Parsons QuickVerse 2005 Expanded Edition...
I cannot get my software to install and function
NOTE: QuickVerse Smart Tags will only work with Microsoft products that support the technology. (Your version of Microsoft Word must be 2002 or newer.)
during the installation of QuickVerse. However, if a Microsoft document was open during installation, you may have to walk through the following steps manually.
Phase 1 - Manually register the QV13SmartTags.dll file
  1. Download and extract this ZIP file to your desktop
  2. Windows XP: Right-Click and select Open
    Windows Vista: Right-Click and select Run as Administrator
Phase 2A - Turn ON Smart Tags in Microsoft Word 2007
  1. Start Microsoft Office Word 2007.
  2. Click the Microsoft Office Button, and then click Word Options.
  3. Click the Proofing tab, and then click AutoCorrect Options.
  4. Click the Smart Tags tab.
  5. Verify that the Label text with smart tags check box is selected and that your smart tag is both listed and selected in the Recognizers list.
Phase 2B - Turn ON Smart Tags in Microsoft Word 2002 or 2003
  1. Start Microsoft Office Word 2002 or Microsoft Office Word 2003.
  2. On the Tools menu, click AutoCorrect Options.
  3. Click the Smart Tags tab.
  4. Verify that the Label text with smart tags check box is selected and that your smart tag is both listed and selected in the Recognizers list.
click on this link directly for more troubleshooting
http://www.quickverse.com/shopfiles/Faq.asp?ID=41221
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 28, 2009 | Findex QuickVerse Bible Suite 2008
I am asked to close microsoft dod before I can install quick verse 7 How do I do this
Most likely you'd have to uninstal MS Office, as I think this is the program using Microsoft DAO. Restart the computer in Safe Mode, then Quickverse will instal ok.
Jul 15, 2009 | Parsons QuickVerse 7 Essentials (fe11044)...
Parson's quickverse 8.0 doesn't show greek and hebrew fonts on my Vista machine but it worked fine on my Windows XP machine???
it is possible that your sytem does not contains the additional fonts required
download these fonts and drag drop them into the fonts folder in the control panel and select install when prompted
Jul 07, 2009 | Parsons QuickVerse 2005 Expanded Edition...
I have used Quickverse VErsion 7 Deluxe for years on previous laptops using Windows 98 and Windows XP. However, I have installed it on my new laptop using Vista 32 bit and if I right click on the desk
From their website
Question 1:
Can QuickVerse 2007 run on Windows Vista?
Answer: Configure QuickVerse 2007 for Microsoft Vista Compatibility Mode
  1. Download and install the latest Maintenance Release
    Browse to the Program Files folder for QuickVerse 2007
  2. Configure Compatibility Mode for these 2 files:
    C:\Program Files\QuickVerse 2007\qv11.exe
    C:\Program Files\QuickVerse 2007\QVBookManager.exe
  3. Right-click each file listed above and select Properties on the Menu
  4. Click on the Compatibility tab and make the following selections for both files listed above:
http://www.quickverse.com/Shopfiles/Faq.asp?ID=QV2007WIN
Apr 23, 2009 | Computers & Internet
Installing QV 7 produces warning MS DAO preventing installation.
I,too, have the problem of installing my Quickverse 7 on my computer with Vista. What do i do to stop the running of Microsoft DAO?
Apr 08, 2009 | Parsons QuickVerse 7 Essentials (fe11044)...
Get started with quickverse white box
Go to quickverse.com download white box 2.02 upgrade.
Feb 20, 2009 | Navarre Quickverse Mac Bible Study 2007...
I tried the following and it works. I had several bad installs and this works. My guess is that the first steps are not necessary, but they won't hurt.
1. Insert the first CD and explore to find the autorun file. Right click and choose properties, and run it in compatability mode with Windows 98.
2. Right click again on the autorun file and choose to run it as administrator.
3. Follow all the regular steps for installation.
4. On the new shortcut, right click and choose properties, run in compatability mode with Windows 98.
5. Finally, right click on the shortcut icon and choose to run the file as administrator.
Good luck. It is a wonderful software I have had for ten years and used on a half dozen computers.
Nov 17, 2007 | Parsons QuickVerse 2005 Expanded Edition...
Quickverse 5.0
I had the same problem [Quickverse 7 on a Vista OS] but my fix was a little longer. On my right click on the icon I didn't get a Compaibility tab. I went down to "properties" then in properties the tab for compatibility shows up. Click on "Run this program as an administrator." This worked fine for me. And this site rocks with so much great information - thanks everyone for your input and for sharing!
Nov 12, 2007 | Parsons QuickVerse 2005 Expanded Edition...
Computers & Internet Logo
208 people viewed this question
Top Parsons Computers & Internet Experts
Neil
Level 1 Expert
tdk1988
Are you a Parsons Computer and Internet Expert? Answer questions, earn points and help others
