Question about Dell Office Equipment & Supplies
Dell 1700 laser printer
I have replace the toner and drum and still printing out blank paper..no error messages i have turned off and try to reset but still nothing
  • 49 Answers
Call Dell. the 1700 has special reset instructions for resetting the drum count.
Posted on Feb 27, 2009
Close door or replace cartridge message won't go away
Dell growing very fast in computer market because Dell provide best and affordable products to users but one thing is confronting by many users is that "Close door or replace cartridge message won't go away" that's why Dell experts provide a toll-free Dell Support Phone Number through which number every Dell user can easily connect with Dell experts and solve issue within a couple of minutes. Don't late to call because Dell experts provide first come first serve service so call anytime without any hesitation 24x7.
Jan 08, 2016 | Dell 5210n Laser Printer
Dell says I low toner, replaced cartridge, same message
Unless your 'new' cartridge has a used chip, it's likely that the pagecount for the Photoconductor/Drum Unit is at the replace stage. The Drum unit has a small waste toner collection container, is this becomes over-full, waste toner 'spews' into the printer with dire effects. This is ONE of the reasons that drum units have a rated pagecount. You can reset the drum counter without actually replacing the drum, but this should be used as a short term measure ONLY, AND AT YOUR OWN RISK. The Photconductor reset procedure is as follows.
Dell 1700
RESETTING DRUM PAGE COUNTER
1) Leave the power on, insert toner cartridge, and leave door open
2) Press the cancel button and hold till the leds flash
3) Release cancel button and close toner cartridge door
Aug 29, 2010 | Dell 1700 Laser Printer
Dell 1700 is giving me an error about the Toner. It also prints out a page telling me to replace the photoconductor kit. I have replaced the photoconductor and the toner but it still has the same error and...
The printer has no way of knnowing that you have changed the Photoconductor Unit, unless you tell it (as there is not chip on the Photoconductor).
Dell 1700
Apr 08, 2010 | Dell 1700n Laser Printer
My Dell 1700n Drum and Toner Cartridge were both replaced when the drum replace light blinked and the print was getting lighter. Despite resetting the Drum counter the printer still only prints faintly...
Have you checked the fuser?
A laser printer fuser assembly is the heating roller unit that melts and fuses the toner onto the paper. The fuser assembly is made up of a heating roller and a pressure roller.
The heating roller applies the heat to the toner on the printed page and the pressure roller presses and fuses the toner into the printed page. If it's bad and not heating properly, the print will be faint, which is what you describe. You may be able to remove and clean the fuser, but if the printer gets lots of use, it may just be worn out.
See this link for an idea of what it looks like and a price.
http://www.fastprinters.com/ProductDetails.asp?product_id=DELL-H4919
I do not work or represent this company, so shop around.
Mar 22, 2010 | Dell 1700n Laser Printer
Ink on the edge of the page everytime we print a document.  we refill our toner, but have done so for years.  dell says that it is bc of the refilling and that it has filled up our drum??? any...
The Dell 1700 cartridge can leak from a failed mylar blade that sits against the Developer Roller.
The plastic locking ring on the and of the Developer roller spindle (of the toner cartridge) can come loose, or break (over time).
The drum unit has a relatively low capacity to hold waste toner, and all toner is not the same (waste toner shouldn't be re-used - it will just fill up the waste section of the drum even faster). Some toners are more efficient than others.
If you reset the 'replace drum' indication, without actually replacing it (or at least emptying it) you will soon have the drum over-full of waste toner, and the only other place it can go then, is inside the printer, and onto the paper.
Jun 23, 2009 | Dell 1700 Laser Printer
Flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
May 28, 2009 | Dell 1700 Laser Printer
Dell 1700 laser printer has Low toner and error lights flashing
Leave the printer on. Open the front and hold down the cancel button until all the lights are flashing in sequence. Close the front while still holding the cancel with the lights flashing and then release the cancel button. This should reset it.
Thanks
Nov 07, 2008 | Dell 1700n Laser Printer
Dell printer 1700
First unplug power cord and plug back after 10 mins.
If problem persists, then it is probably a toner error, if the toner is nearly finished. In this case you will see the led flashing only when is printing. Sooner or later the printer will start printing blank or faded pages and you will need to change toner
When is not toner, with same symptoms as above, it can be drum error, in this case printer will keep printing but shows flashing light, at a certain point you will need to change drum kit.
If light flashes and printer does not print, then it is either paper jam inside, or one of errors above at final stage, or one of the door not well closed (check them all), or printer faulty (fuser, heads mechanics etc.), in this last case call service.
Mar 21, 2008 | Dell 1700n Laser Printer
1,000 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
