Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My washer spins slow.
I bought our washer back in 2002 from ABC Warehouse. I never had any problems with it until recently. All of a sudden the washer only has one spin speed, SLOW!!!
After it does it's course the clothes are wet as can be. I kept the door open during all of the different spin cycles & there is not any difference between the low, regular or the high spins.
Has anyone had this problem before? If so, is their a cure?
  • Whirlpool Master
  • 3,361 Answers
Check your direct drive coupling and your clutch.
Posted on Feb 25, 2009
I bought my Vizio smart TV from ABC Warehouse 2014 it is not even 3 year old yet . when i truned it on the other day it maked a buzzing noise and shut off and it will not turn back on HELP PLEASE!
Something in the power supply gave out, your going to need a new board, don't order boards by model and make, use the part number on the board...you can get a replacement board from shopjimmy.com or ebay
Oct 21, 2017 | Vizio Televison & Video
Took car to abc warehouse got radio hooked up now my dash and tail lights won't come on
I would take it back and talk to maneger if they dont fix it call the BBB and put a complaint in on them and you will get some results from the abc .
Feb 24, 2011 | 1995 Dodge Intrepid
Washer agitates but will not spin drain spin or fill
Well I have a Roper Top Load Washer, bought it in 1998 ,no problems til back 6 years ago we had someone come fix it. My problem was the same wouldn't drain or spin. The problem was it was clogged, in the front when you lift off the washer casing theres a white piece connected to to tubes that drain. well there was my daughters pair of underwear in there and a couple small socks. He took them out put it back together and worked ever since. Until earlier tonight we had same problem so we took it apart ourselves and found my boyfriends sock in there took it out and put it back together and works great again. So far so good. Hope this helps Good luck. Tammy
Nov 05, 2010 | Whirlpool LSR8433K Top Load Washer
Washer will not stop!
call a service technician to get a proper diagnosis and quote then decide to fix or junk
Jun 10, 2017 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Kenmore 80 series spins but won't ring out clothes
Check for buildup of detergent/foaming while washing. Check for oil leaks around the clutch area. Could also be the clutch lining is worn out. Replacement parts kit includes all parts
Mar 06, 2009 | Kenmore 22422 Top Load Washer
Front load washer not spinning correctly
I had the same problem, once I remove the shipping bolts on the back of the machine it worked fine.
Feb 01, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Jul 14, 2008 | Kenmore 23822 Top Load Washer
GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Jul 09, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
103 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
