Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Dect 6.0 had static and echo feedback on all handsets
The person I call or who call me cannot hear this. I am the only
one who hears the problem. The person I am talking with is
not always clear.
  • Anonymous Mar 02, 2009
    same problem I cannot make a call or receive one. There is either static or echo. Model DEC2080
5 Suggested Answers
SOURCE: The other party cannot hear me from one of the Uniden DCX 640 handset
don't hear with uniden 640 dcx
Posted on Nov 07, 2008
SOURCE: I have a uniden dect
Hi, I have a dect 2035 and began having the same problem. I don't know how the feedback came about but it was suddenly there today when I tried using the phone. After mucking around with one of the handsets I hit the speakerphone button and turned the volume all the way down, it only goes down to a preset minimum, I then turned speakerphone off again and turned the volume for regular handset mode all the way down too. The phone works beautifully again!
Posted on Feb 13, 2009
  • 10 Answers
SOURCE: I unplugged the base and the handsets for a few
Find a small gray box on the outside of your home called a "network interface device". It's likely near your electric meter or somewhere on the rear or side of the house. Open this up with a screwdriver. Find where your line is marked in there. Plug in a simple non-cordless type phone into the rj11 jack inside the interface. If there's still no dial tone call your phone provider and they'll repair the problem for free. Be sure to check it at the interface because the phone company bills for anything past the interface if you don't have a maintenance plan. They put that interface, called a NID, there so you can isolate problems before unnecessarily calling them to dispatch out a technician. If you don't have an interface or can't find it, call the phone company and they'll install one for free.
Posted on Aug 30, 2009
  • 31 Answers
SOURCE: the phone (GE DECT 6.0) handset states "out of range.
ther is problem in hanset u have to change ur handset
Posted on Sep 29, 2009
SOURCE: I can hear but the person I am talking to cannot hear.
try cleaning the mic' without openning the phone -
from the outside by an old touth brush...
that will do the trick
if you can open the screws without any damage
than pull out the mic's cover
it is probebly full of moist
Posted on Jan 24, 2010
Dial tone sounds static and voice echos. How to fix?
Hi anonymous, ;)
You can try to reset the phone by disconecting the battery..
Rconnect and place it on the receiving unit to reconnect it to the network
Apr 20, 2015 | Uniden DECT 6.0 Cordless Telephone...
Set greeting on uniden dect 6.
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Jan 19, 2014 | Uniden DECT 6.0 Cordless Telephone...
All phones have static called at AT & T and no success clearing static
The most common cause of static on the line in your home is a bad or loose wire. If all your phones are experiencing the static, it would indicate that the bad wiring is before the first phone. Check the network interface device (NID) on the outside of your home first. If you are able you could bring one of your phone outside and listen to the static as you move wires around inside the NID. Make sure they are all tight and no bare wires are touching or shorting. If you don't find the problem there check as much wiring as you can get to. If you move or affect the problem you should be able to hear it in a handset. Then check all of the phone cords especially handset cords and phone cords on the floor. I hope this helps you solve the problem. Have a wonderfull day
Sep 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
Info to change message on telephone dect 6.0 telephone Uniden dect 6.0
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time.
  1. Press the /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
Jan 06, 2010 | Uniden DECT 6.0 Cordless Telephone...
I am unable to record my message on my Uniden DECT 1580 phone. It tells me to go to command 8:RECNEWGREETING. My question is where the hell do I find command 8?? Jesse
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Press /mute on the handset. The system announces the number of new and old messages, and then starts to play the messages unless it has no messages.
You will hear intermittent beeps indicating that the system is in the command-waiting mode.
The system announces, "Record greeting."
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Press /mute.
Oct 30, 2009 | Uniden DECT 6.0 Cordless Phone ID
Poor quality of voice and can't hear the
My DSL filter had gone "bad" I needed to replace the inline filter.
The suggestion was also to move the base unit away from the kitchen area because of all the technology that I had happening in one area.
Jun 11, 2009 | Uniden Cordless Phone
Tesco ARC200 Cordless DECT Phone
[ARC20x User Guide p20: 11 Handset Registration]
To register a new handset:
  1. Press and hold the HANDSET LOCATOR on the base unit until you hear Registration tone (repeated 'beeps')
  2. On the handset, press the PROG then the UP or DOWN button to display "REGISTER"
  3. Press the PHONE/OK
    -> The display shows "BS 1234". If any of these numbers is steady (not flashing), then the handset is already registered to that base unit.
  4. Press 1 to select base unit number 1
    -> The display shows "BASE PIN _ _ _ _"
  5. Key in the system PIN (default 0000) and press the PHONE/OK
    -> The display shows "WAIT _ _ _ _" for a few moments, while the handset searches for a base. Then it shows a list of handset numbers which are still free on the base unit.
    (For example, "1 34 6" indicates that numbers 1, 3, 4 and 6 are free; 2 and 5 are already assigned to other handsets.)
  6. Key in a free handset number
    -> After a moment, the display should show the handset's name and number.
If registration fails...
  • Try again, making sure you begin step 2 as soon ans Registration tone starts.
Nov 08, 2008 | Uniden Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
78 people viewed this question
Top Uniden Lands Phones Experts
Dave Ellis
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
