Question about Sony VAIO VGN-CS220J/W Notebook
VAIO VGN-CS215 J doesnt turn on
I have a problem with my laptop which I bought one month ago. few liquid has been spilt on the right side. It was working; afterwards I hibernated the pc and tried to awitch it on. It didnt work. The battery lamp is turned on all time and whenever I connect the adaptor the blue light in the bottom switches on for 2 seconds along with the fan, then switches off and the I couldnt turn the pc on. Is it a serious problem? Does this indicate a specific thing in the computer has been damaged? Can it be it need to be cleaned inside by a technician?
  • 2 more comments
  • emankhafagi2 Feb 25, 2009
    Actually it was spilt on the right side on the latop and didnt reach the keyboard at all. I have unscrewed the the perforarted compartment at the back, few minutes after this happened and I found residue and only one drop reach the body inside. Is it an indication for anything? Is it serious?
  • emankhafagi2 Feb 26, 2009
    I wanted to clarify that this residue has reached the computer from the back and didnt path from the top of the computer and reached the back. Actually this happened during I was wiping the right side of the computer and I moved the tissue while wiping to the back of the computer. Due to the presence of perforations in this chamber, the heavy liquid passed through it (thick soup). Then I opened this compartment and cleaned it and found only one drop reached the body (may be during I put the computer upside down). Do you think the whole motherboard has been damaged?
  • Mr fix.it May 11, 2010
    if you found residue liquid then liquid has reach the innards of the laptop so its best not to try switch it on again and take it to a qualified tech.
    I have a couple of dismantled laptops pics on my site just to give you an idea the complexity of whats running inside that little "box"
    If the spill has reached the mother board then most probably the mboard has been damaged however you will not know unless the laptop is totally dismantled. If you unscrew the memory compartment from the bottom do you see any spill residue ?
  • 78 Answers
If the pc cannot be switched on it is useless buying a post test card. since something might have been damaged internally you might need to take it to a professional to be able to open it up. if the battry contacts or power contacts are wet or have been wet whilst powering on then some level of damage might have been done to the board. but the last word counts only when the laptop is dismantled.
I am sorry but if it has no response at all there must be something with the power section.
Posted on Feb 26, 2009
  • 203 Answers
You need to take it to a qualified technitian.
it could be any number of problems.
you could have battery problems or motherboard issues.
even a broken graphics adapter could stop your laptop from powering up.
if liquid has been spilt onto it then get it checked.
it may be a simple fix but it also may be very costly.
Posted on Feb 25, 2009
  • sean sutton
    sean sutton Feb 26, 2009
    you could not say if the motherboard has been damaged unless you test it.
    you can buy POST TEST cards from ebay for about £10 incl post.
    make sure you get one that plugs into a parallel port or usb and not the pci socket card.
    this will tell you if you have a broken or damaged board.
I have sony vgn-cs215 with win7 os. but my AV MODE is note working and I am very much confused that which driver I want to download from the following link...
hi i recommend to download vaio update and it is only 4 MB size. once you download the tools it will get you all the update required by the laptop. Even your using win 7 it will download latest update make sure you enable auto update in Win 7. you will find the update tool in contol panel.
I hope this will resolve the issue.
Jun 17, 2010 | Sony VAIO VGN-CS215J/W Notebook
Fuzzy line going right down right side of Sony Laptop VGN-CS26g
The pixels inside of the LCD are going bad. Your screen is going to need to be replaced. When pixels in screens go bad it usually turns colors or gets fuzzy after it heats up.
May 14, 2010 | Sony VAIO VGN-CS260J/P Laptop
Se formateo sony vaio vgn-cs215 y se instalo win
I Understand, but My portuguese is not up to answer in that language, so translate this.
Formatting the hdd wiped out your restore partition, the only way out is to contact Sony and order a restore disc. it will cost money, but you can order a vista restore CD.
It is the only way.
Dec 08, 2009 | Sony VAIO VGN-CS215J/W Notebook
Sony Vaio fan making noise
Hi:
Not sure of a user cause for the fan to run full speed, unless you are using the laptop in a high heat environment, or setting it on a bed or other area where it is not getting adequet cooling air. If it does it right away, when you turn it on , cold, then there might be a laptop hardware problem. If you leave your laptop on all the time, then you might be inducing the problem. I had a HP high performance laptop, that the fans would not turn on at all till it ran an hour or so, then they would stay on loud for 10 or 15 minutes, then shut off, then cycle.
Nov 10, 2009 | Sony VAIO VGN-N130G/W Notebook
WIO care-VGN-CS118E is getting off automatically
check it on authoized serice centre
there is problem in motherboard of laptop which is in warrenty
Jul 28, 2009 | Sony VAIO VGN-CS118E/P NoteBook
My laptop turns itself off, sometimes in 15 min, sometimes 5h
change the power setting on your laptop to balance
Jul 11, 2009 | Computers & Internet
Bought 6 months ago and will not boot up, with battrey out it will attempt to start for a couple of secs and then nothing
After 8 days of no life at all in the laptop , having 2 computer technicians around saying it was probably the motherboard and just about to send to Sony I pressed the power button and hey presto it worked again..Guess it was just sleeping or hibernating...after all it is spring now....Actually one guy of the many forums I have visited advised just to leave the Laptop alone and perhaps it would mend itself..and hey presto he was right, although having said that I have yet to turn the laptop off and startup again..HMMMMMMM...
Apr 14, 2009 | Sony VAIO VGN-FS630/W Notebook
Vertical lines on Sony VAIO Digital Studio VGN-AR320E PC Notebook
You can't. You'll have to replace the lcd. You'll just keep getting more and more until your lcd dies completely.
Feb 19, 2009 | Sony VAIO Digital Studio VGN-AR320E...
Sony vaio vgn fw21l,loose hinge
I am a PC Technician, I also happen to own a Vaio with this cool but very fragile power button. It will be okay to leave it like that.I had the same issue and I repaired mine because I have experience tearing down laptops. The labor to get to that little plastic piece is extensive. If the situation arises I can explain to you how to do this, ill even have pictures as it is nearly impossible to find service manuals for new Vaios. But it will be fine if it is a little loose.
Feb 18, 2009 | Sony VAIO VGN-FW140E/W Laptop
Sony VAIO VGN-CS220J/W Notebook Logo
640 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
