Question about RCA P52926 52" Rear Projection Television
TV comes on but no picture now.
Greetings all! I have an RCA P52923 model rear projection television. I was moving the TV from to install my new home theater receiver when it became unplugged (it wasn't turned on). When I plugged it back in, it would not say anything! After fuming for about an hour, I took of the back panel and noticed that the fuse (5g5a125v) was burned out. I have replaced the fuse and I get sound and can change the channels, but now the lamps will not come on! Firstly, is the fuse a specicfic type? What does the 5G mean? I have a 5 amp 125 volt fuse in there, but does the particular fuse the TV uses have something special about it? If so, where can I get it? None of the local vendors have it. Finally, if the fuse is not specialized, what else can be wrong? Any ideas how much repair is? I don't need a hulking box in my living room. Any suggestions and advice would be greatly appreciated. Thanks in advance!
Change the bulb in the projector
Posted on Feb 24, 2009
I have a RCA 52'' model # P52923, I was watching TV and the TV went out, I replaced the fuse, and I got the power back, but now the picture is can of caved in and now the picture is can of blurrier and...
On board above your deflection board there is a Black IC which is the regulator IC STK730-010 or020 Call Mats for Part 1-800-628-1118 go by number on the IC
Nov 23, 2009 | Televison & Video
TV doesn't have picture
it could be several things..no high voltage..bad tube...crt board problem..suggest you take to repair shop...compare prices of new tvs...repair at least 150$
Mar 22, 2009 | RCA P46924 46" Rear Projection Television
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
Rca tv no picture
you need a cable spliter coming from the wall and two cable boxes
Sep 05, 2008 | RCA P52926 52" Rear Projection Television
RCA Projection TV Model P52923
Good Day, Ajejo;
Sorry I'm not Circuit City, but work for them for many years down here in TX.
The chassis number is the best way to find out information about the TV. The CTC195K3 is very commonly known to have bad 'flyback'. The crusting you indicated on top of said transformer is the indication that it is defective, I've changed 80-90 of them over the years.
So, job well done, your wife must be proud of you.
Part information: Location; T14401, Part Number; 239111, Name; IHVT, Integrated High Voltage Transformer.
Caution when replacing the fly, looking at the bottom, the pins are shaped like a horse shoe. At the closed end there is an separate pin. Make sure new has the extra pin (for focus), Iv'e had many lately that does not have it.
Good Luck, big IRISH. PS; good job good eye let me know.
Jul 11, 2008 | RCA P52926 52" Rear Projection Television
Looking for blue projection tube for rca model p52923 tv
you can get a blue tube for your rCA at the following link, leave them a email and state the model number of your set and what your needing
http://servicemanuals.vstore.ca/
Jun 27, 2008 | Televison & Video
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
288 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
