Question about Kenmore 57029 Side by Side Refrigerator
Kenmore fridge replaced motor starter and overload fan working on back noter slightly warm to touch no fans blowin inside
  • Anonymous Mar 05, 2009
    only the light works the refrigerator stopped cooling nothing else is running - it is silent
  • Ken Bledsoe May 11, 2010
    Your fan is not working inside the freezer? Just to get this clear right?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check cold control
Posted on Apr 02, 2009
Fridge not cold enough, freezer is. How to get the fridge colder?
If there is still ice in the freezer it will need to be completely defrosted for air to circulate through the coils. Make sure the fan is turning in the right direction. a generic fan motor may not be turning in the right direction and will need to be reversed by turning the armature around if this is possible with the replacement motor most universal motors are reversable and should show you how in the directions.
Oct 04, 2014 | Kenmore Refrigerators
The evaporator fan motor will run only when the compressor is running. If the temperature is too warm in the refrigerator, there may be something blocking the opening from the freezer to the refrigerator.
. kenmore side by side blows warm air, after
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 30, 2011 | Kenmore Side by Side Refrigerator
Frig won't cool RM2652
You'll need to get in touch with the store you bought it from but Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Jun 26, 2010 | Dometic RM2652 Refrigerator
Kenmore fridge not cooling
try www.partselect.com
would help if you had a part number
Sep 30, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
253 55682402 Kenmore Side by Side Refrigerator Not Working. Freezer is not freezing and the fridge part is not cooling properly. Also water to ice maker and instant water in front of door stopped working....
How to check stuff>
Aug 21, 2009 | Refrigerators
Inside of fridge is hot. everthing is spoiled
How to check stuff>
Jul 12, 2009 | Magic Chef Refrigerators
Kenmore 106.72102100 Not cooling URGENT!
behind the back panel that you pulled off is where the compressor is. on the left side of the compressor is where the relay/overload is plugged in. its gone bad. if you touch the compressor it will either be really really hot or room temp. unplug it let the compressor cool and replace the relay/overload to fix your problem
Nov 27, 2007 | Kenmore 65812
Kenmore 57029 Side by Side Refrigerator Logo
174 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
