Question about Abit IS7-E2 Motherboard
Abit IS7-E2 monitor wont display anything
Abit IS7-E2 fitted motherboard all done right, but vcc red light is on and monitor wont display enything help
  • hemmings2004 May 23, 2009
    Hi ive got the same problem with this board, ive got power to the graphics card cos the fan on the graphics card is spinning, i power up the computer the monitor tries to switch on but goes back to standby, does this twice and then i get a beep lasting 5 seconds, dont know what is wrong, ive fitted well over 1000 motherboards in my time never come across this problem before any help .
  • 203 Answers
Is this a brand new motherboard?
do you have onboard graphics or a card?
without testing i couldnt say for sure but it sounds like you are not getting power to your graphics on motherboard.
this is usally a common issue for asus motherboards. not easy to fix.
if your motherboard is new i suggest a replacement from the seller.
Posted on Feb 25, 2009
Dont have the install disk
Hello here is the abit homepage:
http://abit.ws/page/mi/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
Try to remove the cmos battery, and insert it again.
This will reset the bios to factory defaults.
You will need to setup the whole bios, date, clock, boot settings when the job is done.
But the power supply could also be failing, or a ram module.
Good luck
Jan 01, 2013 | Abit IS7 Motherboard
Does the motherboard accept 1gig high definition ram chips
The Abit IS7 motherboard only supports DDR RAM. So if you're thinking of upgrading, do not purchase DDR2 or DDR3, because your motherboard will only support DDR memory, at a maximum of 4GB.
Nov 20, 2010 | Abit IS7 Motherboard
My computer wont show anything on the monitor though the cpu fans are running..and there's no disk activity until i unplug the ide cable...
Remove the memory from the slot near to the fan and place it to the other slot then on the system. If it doesn't come up then remove the cmos jumper and clear the cmos battery. I guess it should work like that.
Mar 03, 2010 | Abit IS7 Motherboard
Abit is7-e2g shuttdown
observe the CPU temperature,
it could be a heat issue,
try to reseat your heatsink then wipe the old thermal paste and put a thin layer of thermal paste
hope this thing helps
Jan 31, 2010 | Abit IS7-E2G Motherboard
Hi! I have a pc with abit is7-e2 motherboard.. And when i start the pc a red led turns on the board... There is no picture on the screen. I already checked the video card but its working
Just how did you check the video card if you get no image on the screen?
Try another monitor with your computer. If you still get no image, then it's your video card or another component.
If your computer will not pass the POST (power on self test) then you will not get any video output.
Culprits can be the hard drive, the CD, the memory, the motherboard, or the CPU. I would disconnect everything but the CPU, memory, and video and try to start it to narrow the problem. But first, try another monitor.
I've even seen a bad power supply that seems to work keep the video from working.
Jan 16, 2010 | Abit IS7-E2 Motherboard
Sata harddrive max size for abit is7 e2?
hard drive can be as much you want does not have a max size ,anyway not the motherboard you have to worry about if you put bigger hard drive you shold change the power source .
Nov 13, 2009 | Abit IS7-E2 Motherboard
Hey guys would you be so kind to try to help me out? a friend brought me a pc with an abit IS7 motherboard it can't boot instead, all fans start working then a red light, 3 short peeps and it stops. What...
The beeps might indicate the problem with RAM. Try plugging out the RAM modules and insert them back in one by one in different slots and then check.
Jul 17, 2009 | Abit IS7 Motherboard
Upgrading abit is7 mobo
You can upgrade to a celeron-D 3.2ghz or a Intel P4 3.4ghz.
Please rate my response. Thank you.
Jan 17, 2009 | Abit IS7 Motherboard
Abit IS7-E2 Motherboard Logo
555 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
