Question about Panasonic PanaFax UF-490 All-In-One Laser Printer
Office Fax is telling us to replace drum unt.
The Office Fax is telling us to replace drum unit, we have replaced it, still asking for the same drum unit, no jamming yet
    Genius:
  • 2,120 Answers
Look at the sticker on the machine to get into Maintenance and clear the drum count. I think it's Function 9 set.
instructions should have been in the drum box.
Posted on Feb 24, 2009
We have a Brother MFC -8500 fax machine. Every day
The Drum unit is a consumable.
Buy a new Drum from Staples , Office Max etc and replace it soon.
It will stop and refuse to print when a certain page count is reached.
Jan 07, 2011 | Brother IntelliFAX 2800 Laser Fax
We have a Brother TN350 Fax Machine in our office. It tells me that the drum has dust. How do I get to the drum? Should I replace the drum? How?
If you open the access door there should be a blue slider that you can move side-to-side to clean the corona wire.
Jan 05, 2010 | Office Equipment & Supplies
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
Error Message Drum Life Over, Replace Drum
The "drum" referred to is the imaging drum which is replaced separately from the toner cartridge. The drum life is rated for a certain number of copies, and the printer is telling you it's time. Replacement drums are available at big-box office places and from many online sources. Just do a Google search for "kx-fl511 drum". The new drum just slides in much like the toner cartridge, so replacing it isn't difficult.
Apr 08, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Replaced drum fax 2820
Hi, #'s 6, 7 and 8 below explain how to reset the drum indicator.
Hope that helps...
Lbcoaster
How do I replace the drum unit?
Description:
Follow the procedure below to replace drum unit.
CautionDo NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
spray1.gif Caution
    Just after you have used the machine, some internal parts of the machine are extremely HOT! Never touch the shaded parts shown in the illustration.
  1. Open the front cover and pull out the drum unit and toner cartridge assembly.
Caution
    To prevent damage to the printer from static electricity, do not touch the electrodes shown below.
  1. Hold down the lock lever on the left and pull the toner cartridge out of the drum unit.
Note
    • Discard the used drum unit according to local regulations, keeping it separate from domestic waste. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. If you have questions, call your local waste disposal office.
    • Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the plastic bag.
  1. Unpack the new drum unit.
  1. Reinstall the toner cartridge into the new drum unit. If you put it in properly, the lock lever will lift automatically.
all-ug-16.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Install the drum unit and toner cartridge assembly in the machine.
  1. Press Options.
  1. To confirm you are installing a new drum, press 1.
  1. When the LCD shows Accepted, close the front cover.
Related Models FAX-2820, FAX-2910, FAX-2920, MFC-7220, MFC-7225N
Aug 02, 2008 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 4100 - drum needs replacing
The drum is what the toner goes into. DR-350 or a similar #. You can get at staples or office max.
Apr 09, 2008 | Brother IntelliFAX 2800 Laser Fax
I want to replace the toner unit.
Release lever is for releasing TONER out of drum not for releasing drum... drum should pull out slightly up and forward with toner attached fully. If it is stuck then their may check if a  sheet of a4 is stuck and holding it in.
Oct 10, 2007 | Brother IntelliFax-2820 Laser Fax
All of a sudden my drum unit/fax machine has started making a noise
take off the  two side cover, watch the gear rolling while printing you will find the noise come from, might be one of the gear is broken, certified technician will do the same thing when they troubleshoot the problem too, good luck
Oct 03, 2007 | Panasonic KX-FL501 Plain Paper Laser Fax
Panasonic PanaFax UF-490 Problem with Drum Unit
for manual setting.. when replacing the drum unit.. press function 7 thend scroll down select maintenance then scroll donw select drum unit then press 2 to clear the usage.then press 1 for yes.
jamming or misfed?
try to check the drum unit you install.see if the drum not installed properly. turn off and on the unit
Aug 02, 2007 | Panasonic PanaFax UF-490 All-In-One Laser...
Panasonic PanaFax UF-490 All-In-One Laser Printer Logo
73 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
