Question about Panasonic PV-DV953 Mini DV Digital Camcorder
Need service manual for panasonic pv-dv953d. Firewire plug on computer was plugged on motherboard to USB what caused damage to camcorder. I am retired elect tech will repair it. Everybody is trying to replace main board what is too expensive not wort it. Have too many mini tapes family movies to finish. Just got Sony HDRSR12. Thank you.
  • 473 Answers
SOURCE: USB 2.0 vs. Filrewire - video to PC
Hi I have figured it out. Even if the USB 2.0 is faster than the firewire the camcorder itself do not transfer at the optimal speed when connecting with the USB (even id the USB can transfer faster). So the only fast transfer option is the firewire
Posted on Sep 06, 2005
poolseman
  • 206 Answers
SOURCE: Panasonic camcorder
CCD sensor faulty and has to be replaced. A properly manufactured CCD transduced should last +-15 years so you should isist on having it repaired free of charge by Panasonic agent. ( worst case pay for labor but not the faulty component : 1 hour labour with this problem ).
Posted on Aug 29, 2007
tech48
  • 624 Answers
SOURCE: Panasonic PV-DV953D video transfer to PC
Did you put the camcorder in the VCR mode and make sure it is turned on, so you can transfer the video?
Posted on Jul 30, 2008
SOURCE: No 1384 firewire driver for Panasonic PV-GS300 camcorder
I found the recipe. To get my DV Camcorder to work using 1384 (Firewire) on my computer I did:
1. Get a good cable. If you paid less than $20 for it, you got the wrong one.
2. Ensure that the 1384 (firewire) port is enabled on your computer. Go into the BIOS setup and check to be sure. Mine was OFF!
3. If you get an error with Windows XP not being able to find your hardware, you need to get all the drivers. There are four or five of them along with a configuration file. Miss any one and you are dead. My solution was to reinstall Windows Service Pack 3. This took a long time, but fixed the driver problems.
Posted on Feb 21, 2009
fotomohamed
  • 321 Answers
SOURCE: PV-DV103 will not connect to pc via Firewire - Windows Movie makr
ur COMP. graphic is low. ur camera need capturing card on PC u can edit ur pic in movie maker
Posted on Jun 18, 2009
Jul 30, 2008 | Panasonic PV-DV953 Mini DV Digital...
Cannot download movies from panasonic PV-GS320 doesn't acknowledge camcorder connected from USB or firewire, and no camera in my computer. Usi8ng vista home premium 64 bit
The driver you will need to download to the PC then execute to make it work is at the link here ok.
Bye
David
Lowestoft
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS320.D#ts
May 26, 2010 | Panasonic PV-GS320 Camcorder
Panasonic Camcorder USB Driver for Windows 7 OS
Support site http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/model.PV-GS500
User manual here http://service.us.panasonic.com/OPERMANPDF/PVGS500-MULTI.PDF
The USB driver gven by the manufacturer is not installing on the Laptop. you should NOT need a USB driver with windows 7 - the USB should automatically detect the camera
Apr 21, 2010 | Panasonic Palmcorder PV-GS50 Mini DV...
Plug in to the computer...
It sounds like you're plugging the camcorder in  via USB. Your PC is looking for a flash memory card (SD card on the GS300), which is used on that camcoder for still photos only.
If you want to transfer video from the camcorder, you need to use the Firewire port. DV camcorders do not transferr video via USB (some of the "computer" style camcorders, including most flash, DVD and HDD camcorders, can use USB for file transfers).
Jan 21, 2008 | Panasonic PV-GS300 Mini DV Digital...
Firewire connection not responding
Take a magnifying glass to the firewire port on the camera. Check to see if it looks damaged at all. I've used firewire with my students for many years and this has happened to me on more than one occasion. The student is not as careful as he could be when plugging in the cable. The inside of the firewire cable becomes damaged. This is a cheap fix. Buy a new cable. However, when the port is damaged, it is an expensive fix. Since the computer recognizes another camcorder it may not be the computer. And if you are using the same cable, then it will probably be a hardware issue with the camera. Look at the port and let me know if anything looks out if place.
Jun 29, 2007 | Panasonic PV-GS65 Mini DV Digital...
PV-GS2 Camcorder is not being detected using Firewire/DV port
Hi Here is a link to the latest manual for your Camcorder. Check out page 42. This may help. http://service.us.panasonic.com/OPERMANPDF/PVGS2.PDF You may need to re-install the software o your computer for the camera inteface. Have a Great Day!!
May 04, 2007 | Panasonic PV-GS2 Mini DV Digital Camcorder
Panasonic PV-DV953 Mini DV Digital Camcorder Logo
179 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
