Question about Pinnacle Video Transfer
I am using the Pinnacle Video Transfer device to transfer to Vista computer. I have had several very successful transfers, but have now run into a problem. After every procedure has been followed, including allowing the three blue LED lights to go through their routine, I then unplug the storage device and plug it into my computer. The video file is recognized, but shows zero as the file content. Naturally, nothing is available to copy to my hard drive. What could be going wrong
  • 1,602 Answers
IN A BOOK I HAVE STATES THE PROBLEM IS IN THE SLAVE OR MASTER DMA REGISTER FAILURE,
THE CONTROLLER CHIP IS CORRUPTED, AND THEY ARE LOCATED ON THE MOTHERBOARD AND MOST OF THE TIME THEY ARE SOLDERED IN, YOU HAVE TO REPLACE THE BOARD UNLESS YOU CAN FIND A PROGRAM THAT CAN CLEAN THE SIGNAL OR FREQUENCES UP IN THS AREA IF YOU CONTINUE TO USE IT THAT WILL CORRUPTED THE HARD DRIVE
ROD
Posted on Feb 26, 2009
My pinnacle one touch video transfer device won't recognize my ipod touch..is there something i can do to make it work ?
I bought this device last week online and it doesn't recognise anything: nor my VCR, video camera, DVD player ... ! Do you already have a solution for this ? Could it be an error in the pinnacle video transfer system ietself? If you have an answer , please email me at simon00028@hotmail.com
Feb 24, 2011 | Pinnacle Video Transfer
I donot have software for transferring my video
You will have to buy a capture card to transfer the dv to your computer. Try a Pinnacle made device.
Dec 22, 2009 | E.Digital Sony DCR-TRV265E camcorder Pal
Before buying a pinnacle video transfer I need to know if this appareil is vista compliant
Only requirements I see are video and audio input connections on our PC for the transfer/capture device. There are no actual drivers installed on Vista. If you are using Pinncale Studio software to work with the captured video, they do have versions advertised for Vista and Windows 7. If you have an older version, you may want to check the system requirements for that version. Upgrade versions appeared to be available.
Nov 11, 2009 | Pinnacle Video Transfer
How to capture videos by DCR-HC30 in a laptop
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorderdoes not support USB streaming with the VISTA Operating System. Use ani.LINK cable to transfer the video to the Computer. The i.LINK port isalso called IEEE 1394 or Firewire port. (An i.LINK is a black D shapedconnector with 4 or 6 pins. The type of cable to be used will depend onthe i.LINK port of your Computer. The Sony Camcorder will have the 4 pini.LINK cable and if the computer has the 6 pin i.LINK port, then you mayhave to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE:Asthe Camcorder does not support USB streaming with Vista, it isnot required to use any Sony Device Driver to transfer the video tothe Computer. You do not require any Drivers or Software from Sonyto transfer the video from the Camcorder to the Computer usingthe i.LINK/Firewire interface.
Applicable for Windows XP Operating System:
If youare using a Windows XP Operating System then you have to install the USBStreaming Driver in the Computer from the supplied Software disk withthe Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!!!!
Sep 09, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Video transfer
You need a download hardware from Pinnacle. www.pinacclesys.com You may use a simple one PC/TV card with software. If you are from India, you may get several options like www.monarch.com etc.
Oct 01, 2008 | Hitachi DZ-GX20A DVD Camcorder
Trouble with audio on pinnacle video transfer
I have had this problem several times, and there is a simple solution that has always worked for me. If I clear space on my external hard drive and de-fragment it, it seems to make the problem go away.
Sep 11, 2008 | Pinnacle Video Transfer
Pinnacle video transfer
there is no website which provides it for free
The Pinnacle Video Transfer is available from the Firebox.com website for £99.95
log on to
http://www.firebox.com/product/2152/Pinnacle-Video-Transfer/
and check it out
Jun 07, 2008 | Computers & Internet
Video transfer
You can stop and start as much as you want. Then you just hit play and record it onto your pc with the software. There is software you can get that will know when you start and stopped and will break your video up into scenes automatically onto the computer.
Hope that helped,
Lee
Jun 07, 2008 | Pinnacle Video Transfer
PINNACLE PRO
Probably you need to do this in two stages.
1. Save the movie to your HDD -
www.vdownloader.es is good free software for saving clips, for example, from youtube etc.
2. You need a video card with a TV output to transfer the clip to your TV screen. Maybe your Pinnacle card can do this?
Hope I understood your question correctly.
Cheers
Apr 03, 2008 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Pv-L750 camcorder
I have a Panasonic camcorder PV-L750D-K
You will need to purchase Pinnacle Video Transfer.
http://www.pinnaclesys.com/images/redesign/PVT/comp1.html?KeepThis=true&TB_iframe=true&height=400&width=650
It's expensive, but it's the most convenient way to transfer analog video (via a USB flash stick or external hard drive) to view and edit on a PC.
I have used this device with my Panasonic PV-L750D-K Palmcorder (camcorder) with success.
A few things to keep in mind:
a.) The Pinnacle Video Transfer converts the the video into MPEG 4 format - so you will need the Apple QuickTime viewer to view the videos on your PC.
b.) You will need to purchase a USB flash stick, a min of 4GB (I use an 8 GB flash stick), unless you have one already.
c.) Your flash stick should be formatted to FAT 32
d.) You will need the Audio/Video cable that came with your Panasonic camcoder (the supplied A/V cables that come with the Pinnacle Video Transfer are incompatible with the Panasonic camcorder).
e.) You will need to update the Pinnacle Video Transfer with the latest firmware update (available from the Pinnacle Support Site) before you hook everything up.
The rest is a no brainer. Just follow the instructions in the booklet, or view the tutorial videos on the pinnacle web site for more info.
Have fun.
~appaloosa
Jan 01, 2008 | Panasonic PV-L750 Camcorder
Pinnacle Video Transfer Logo
325 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
