Question about Proscan PS50700 50" Rear Projection Television
50 in. HP plasma made loud pop noise and stopped working.
Unplugged unit and waited 10 min. now won't come back on, power light goes off and on with some clicking noises.
  • Anonymous Feb 27, 2009
    TV went dark, now with it turned off it keeps clicks.
  • 90 Answers
Clicking is from the relays -- sound like the power board went out--
go to partstore.com
Posted on Feb 24, 2009
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
After disconecting the power cable from the outlate,ploget back in and the tv dos not come on. red light blinking constantly
that it is likely a power supply problem. It starts with a loud popping or crackling noise and then the set goes dead, except for a flashing red light on the front. best thing to do here is to unplug it from the power for a good min or 5 make sure the TV is not hot and try plugging it back in , also Plasma TVs and Samsung have had this problem for a long time this is the info i found for you.
The Panasonic Viera 50-inch plasma TV has received rave reviews from the media and consumers alike. Panasonic encountered problems with its plasma TVs last year, both due to degradation of the picture quality over time, which was much publicized due to a class action lawsuit filed over that defect, and for a power supply issue that was far less publicized, but for which there are many negative reviews online. So far this year, though, the reviews have been much more positive. I would like to share, however, that my experience has been less than positive in hopes of helping others who have had the same problem and in providing another viewpoint for those considering purchasing this TV.
Jan 23, 2011 | Samsung 50 in. Plasma TV
My plasma turns itself off for about 10 20 mins
It seems that your unit has some sort of Thermal PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. After it shuts down and the faulty component(s) cool down, it restarts again until it once again goes critical and shuts down again only to repeat the cyle.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Plasma wont turn
unplug it and leave it off for 10 mins
then plug it back in.
Aug 18, 2009 | Televison & Video
Power goes off!
I have the same model as you.
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones and adjust its volume as well).
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Remember that if the audio to the transmitting unit is quiet OR off for about one minute, the transmitting unit will turn off and you will hear FM noise, loudly, on your headphones. This is due to the "lack of audio" timer built-in to the transmitting unit.
May 18, 2009 | RCA WHP140 Consumer Headphones
My 50' LG Plasma made a loud pop and shut off and won't turn on.
warranty not worth the paper it is written on
under warranty it is not a requirement that you fit/ fix anything
the only option is to take it to a repair shop for a diagnosis and quote and then decide if the power hungry plasma set is worth repairing
LED sets use 1/10 the power of plasma units so an upgrade will save money
Apr 07, 2017 | LG 50PX1D 50 in. Plasma Television
Hitachi 42HDS69 42 in. Plasma... Problem
Describe the past - How did it fail? One day or acting up for a while? Could be a weak power supply - a bad capacitor on a power supply too. Look for popped up capacitor top inside.
Apr 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Problem with Pioneer Plasma
Pioneer has a power supply recall on some models. Do a search and you will find a number at Pioneer and they will replace your power supply for free. The loud popping noise and then nothing is a common problem with these. Hope this helps!
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Nov 30, 2007 | Pioneer PDP-505CMX 50 in. Plasma...
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Proscan PS50700 50" Rear Projection Television Logo
251 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
