Question about InFocus ScreenPlay 5700 Multimedia Projector
Infocus 5700 - possible lamp failure, how can I tell?
I bought an InFocus 5700 projector from eBay, it seems to be in good working order as when plugged in the LED turns green and then when the power button is hit the LED flashes green- as explained it should in the manual. However after a few minutes the flashing green LED changes to a flashing red LED. As in the manual I have counted a two second interval between each flash and there is only one red LED flash per sequence, this suggests that "the lamp wont strike after 5 attempts" as the manual states for this error sequence of flashes.
Based on other forum posts I have checked the lamp door and the it is correctly sealed with the door trip switch in working order and switched "on". With this in mind I can only think that the lamp has blown. However it was sold to me on the basis that the lamp has only 200 hours, so it should be fine.
Inspection of the lamp has me wondering. In the silver part of the lamp there are two holes each with a small metal ring around the hole. Only one hole has a filament wire coming from it to central column in the lamp whilst the other hole is empty.
Does anyone know if there is supposed to be two filament parts, one coming from each hole or even better can someone send me a picture of an intact bulb? If I can gather as much information about how to inspect the bulb for if its blown as possible, it could save me £300 should it mean I don't end up buying a spare bulb I don't need!
thanks
  • 17 Answers
SOURCE: Infocus X3 light tunnel
Are you speaking of the small prism shaped tunnel or the lamp itself? The prism or light tunnel may be accessed underneath the metal bracket that holds the color wheel in place. Be extremely careful as even breathing on this may cause it to collapse (ok, I exaggerate).
Posted on Feb 19, 2008
  • 26 Answers
SOURCE: InFocus LP600
If the counter expired, then the reset is holding both volume keys down for 10+ seconds.
Posted on Feb 28, 2008
Marrie
  • 563 Answers
SOURCE: lamp didnt strike
Hi there
You should reset the lamp timer as this LCD Projector's counter counts down the hours and will not fire up if this has not been done.
If you have reset the lamp timer and the problem stil occurs , you'll have to replace the Ballastboard ( lamp's powersupply )
Posted on Mar 26, 2008
  • 4234 Answers
SOURCE: Infocus LP120 Retrying-Power Light Turns Red...
Usually when the lamp is good and you get this message, the ballast is bad. That is the part thatdrives the lamp. Check with Infocus for a repalacement balast.
Dan
Posted on Apr 09, 2008
Mark_Webber
  • 472 Answers
SOURCE: Infocus LP820 - Turns on for 30sec then shuts down
This could be one of two problems I have seen with another model Infocus projector (they are very good projectors though)
The first is the video input. Make sure it is attached correctly at both ends of the cable.
The second, remove the dust covers and blow them out. The problem can arrise if the temperature sensor detects the air inside the unit is getting too hot. If you can see the sensor when the dust covers are off (it will look like a little lump of goo on the end of a wire) then just give it a wipe as well. If dust settles on those it can cause incorrect temps to be reported.
Hope that solves your poblem =)
Posted on Apr 11, 2008
What causes white vertical lines on dlp projector?
Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
Nov 05, 2011 | InFocus ScreenPlay 5700 Multimedia...
Hi, it doesn't power up when I plug it in.
Sounds like the power supply has gone bad. If you interested in getting it repaired you can find me on ebay. Gtitubro is my screenname.
May 22, 2010 | InFocus ScreenPlay 5700 Multimedia...
Hi, My Infocus screenplay 5700 gave a message to change lamp, but after turn it off and then on, i kept working good, after an hour suddenly turned the lamp off but the fans kept working. Now when I try...
the lamps are good for about 2000 hours. but it sounds like it's time to get a new lamp. but after you put it in, go into the menu and reset the lamp timer.
Dec 10, 2009 | InFocus ScreenPlay 5700 Multimedia...
InFocus LP120 Powercycles/Shuts Off/Does Not Stay On
what is the led doing? what coloris it? and if it is blinking, how many times? this will tell you the problem.
green (flashing and solid)- all is well
red flashing:
1 time- lamp won't strike after 5x
2 times- lamp has over 2000 hrs. replace lamp
3 times- lamp failure. replace lamp
4 times- fan not working.
5 times- projector running too hot. needs cooldown
red led lit solid- undiagnosed issue. send in for repair.
if your projector is under 2 years old, it's under warranty, but it seems unlikely.
Aug 10, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
REMOTE
good luck. infocus has nothing having to do with any of the lp4xx series. they don't even have lamps. try ebay.
Apr 11, 2009 | InFocus LP425z and LP435z Replacement...
Infocus 5700 new lamp unit makes variable blowing noise
it will speed up to increase the air flow if the temperature goes up, and slow down when it drops. it's normal. that's how it maintains a good temp.
Jan 19, 2009 | InFocus ScreenPlay 5700 Multimedia...
Projector InFocus LP540
ask the guys at GOTABULB.com Through e-bay they are very good in america
Aug 29, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
Lamp won't stay lit
I've got the same problem, I'm wondering if it has to do with some sort of auto shut off kicking in due to overheating or something, I was gonna try replacing the fan to see if it's something to do with that
Jul 07, 2008 | InFocus ScreenPlay 5700 Multimedia...
InFocus ScreenPlay 5700 Multimedia Projector Logo
304 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
