Marshall amp for 110V, plugged in 220V. What to do?
8 years ago I bought a Marshall amplifier in Sao paulo, Brazil, and used only for a few days. I packed it in its plastic bag in my home. Sao Paulo mains is 110V. The vendor made it ready for the town customers.
Now I am back to my city home which mains is 220. I don't remember using transformer 8 years ago. The first thing I did was to plug into the mains. I heard a faint noise but no more afterwards. The amp sounds dead as there is no static when the classical guitar cord connected to the am is swung.
I am wondering if I damaged the amplifier or just a part of it. That is, I wonder if there is a fuse to protect for such idiot action. Apparently there is no visible apparatus to suggest changeable fuse.
I don't want to send to some adventurer who claims to fix and make it worse. On the back of the amp says not to open it. What can I do?
  • Scott Frye
    Scott Frye May 11, 2010
    Hi...
    The amp will need to come out of the case.
    What model Marshall is it?
    I could tell you where to look for the internal fuses.
What are the ten largest cities in the world?
That is a very easy Google with exactly what you wrote :>)
Rank City / Urban area Country Population Land area
(in sqKm)
Density
(people per sqKm)
1 Tokyo/Yokohama Japan 33,200,000 6,993 4,750 2 New York Metro USA 17,800,000 8,683 2,050 3 Sao Paulo Brazil 17,700,000 1,968 9,000 4 Seoul/Incheon South Korea 17,500,000 1,049 16,700 5 Mexico City Mexico 17,400,000 2,072 8,400 6 Osaka/Kobe/Kyoto Japan 16,425,000 2,564 6,400 7 Manila Philippines 14,750,000 1,399 10,550 8 Mumbai India 14,350,000 484 29,650 9 Delhi India 14,300,000 1,295 11,050 10 Jakarta Indonesia 14,250,000 1,360 10,500
City Mayors Largest cities in the world by population 1 to 125
Nov 22, 2016 | Cell Phones
I bought the amp a few weeks ago and it worked perfectly for a couple of days and then for some reason the controlls just froze. the tap tempo light went out and the channel control light stayed the same...
Exercise your warranty IMMEDIATELY since you just bought it! If you bought this used, you LIKELY bought someone else's problem. The problem is likely in the digital effects area... probably a bad cable contact... but if under warranty DO NOT mess with it... return it for replacement or repair.
Sep 09, 2011 | Marshall Amplification Marshall MG30FX...
I do not see any inputs to connect a subwoofer to my Onkyo A-9555 integrated amp. I would like to know if it is possible to connect it and what kind of subwoofer should I buy for that wit the best...
You amp has no OUTputs for a sub, but if you really want to attach a sub you'll need to get one that is self-amplified and accepts >>>stereo<<< High Level or Speaker Level inputs.
Otherwise your amp's volume control won't also control the sub's volume.
You would feed it full-range audio from the speaker terminals on your amp and its internal amp would use that to develop its own power output for the sub.
Here's one example.
http://www.ch.onkyo.com/files.download/skw-205_manual_e.pdf
Jan 29, 2011 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
I have a Toshiba P15S420 laptop and after years of using it starts to shut down after some time powered on. It works pretty wel until it shuts down. Do you have any ideia what it could be...
overheating issue no doubt have it cleaned and inspected for signs of overheating possibly could be other failures but its a good place to start
Dec 21, 2010 | Toshiba Satellite P15-S420 Notebook
Where are the world largest cities?
TOKYO, Japan
JAKARTA, Indonesia
New York (NY), United States
SEOUL, South Korea
MANILA, Philippines
Mumbai (Bombay), India
Sao Paulo, Brazil
Aug 02, 2010 | Computers & Internet
Will lane assist work with international maps?
lane assist does work if you have navcore8 and a compatible map version 8 or higher
Dec 27, 2008 | GPS
Lambda sensor
Defective oxygen sensor. A scan is required.
Jun 23, 2017 | Volkswagen Jetta Cars & Trucks
Traveling to Brazil fearful of using 220v power outlets
Where u ll be in Brazil. In São Paulo the default voltage of power outlets is 100v.
Here in Brazil the ac adapters comes form factory bivolt (110/220)..
Didnt understand your fear..
send me an email if I can help u. Im brazilian and I live in Osasco-SP.
Good luck in your travel
Dec 05, 2007 | HP Compaq nx6110 Notebook
Lights are gone
Well, If You've Had It For Four Years, It Definitely Sounds Like Your Router Has Died So To Speak. Most Routers Only Tend To Last A Few Years Of Being On Constantly. I Would Suggest Buying Another Router Because The Cost Of Repairing This One Really Isn't Worth it. Good Luck, Brodey
Sep 15, 2007 | Siemens SpeedStream 2624 (SS2624) Wireless...
348 people viewed this question
 Grubhead
Grubhead
