Question about Nokia e65 Cellular Phone
The power button on my Nokia E65 is broken. Is there another way?
The actual thing the power button is connected to is snapped off and i need another way to turn it on any ideas?
  • intention Mar 01, 2009
    thanks but the actual button the power button is connected to is snapped right off the phoone. thanks for trying though.
If the power button is broken then get a bobby pin to stick in the plae of it and push down and it should turn on.>>>>>>>>i have tried it at home and it worked>>>>>>>i have alot of phones to try stuff on to solve questions that people have here.im glad to help.RATE ME>>>>>>>>MAKE IT GOOD<<<<<<<
Posted on Feb 24, 2009
Connected charger on set but eject charger of set soluction plzzzz
Posted on May 23, 2011
Nokia e65 power swich way in motherboard where
Posted on May 31, 2010
Nokia e63 and e65
How to unlock Nokia E65 by code ?
Unlocking Nokia E65 by code is very simply . It is also safest and non-invasive method of unlocking your phone. Code to unlock Nokia E65 will be receive after entering IMEI number. You can get Your Nokia E65 IMEI number by typing *#06# or after removing the battery. IMEI is also written on the information label as shown in this picture.
To unlock your Nokia phone is needed to provide the IMEI number and select the correct network that phone is currently working.
Selecting the correct network and the country is very important. Choosing wrong network You risk receiving wrong unlock code.
If we have blocked counter we need to enter code or reset counter using USB cable by program below
How to enter Unlock code RESET COUNTER to nokia using USB cable
Code #pw+123456789012345+1# type in the following way:
1. Turn on the phone without sim card
2. Select character # on the keypad
3. Characters p, w, + get by choosing few times STAR *
4. Press # button to approve code
5. Message "SIM restriction OFF" appears, Your phone is now unlocked
WARNING!!!
You have only 3 attempts to enter the code. The last failed attempt will block the counter.
Jun 10, 2012 | NEC Cell Phones
FOR HOW LONG CAN THE BATTRY LAST BEFORE YOU CHANGE IT
How Long Does the Nokia E65 battery REALLY last?
Ever wonder how long the phone battery actually lasts? For the first use of my Nokia E65, I charged the phone for 24 hours after receiving it (still not sure if this is necessary), then took it off the charger Saturday afternoon. The battery low warning first sounded 54 hours later. This was after
•Calls: Around 15 calls made and about 3 calls received, with almost 40 minutes call duration in total.
•Data: 726kb data sent and 3.96mb downloaded
•WIFI: About 20 minutes of WIFI use
•Applications: Use of Skype and Gmail application as well as a bit of Nokia Maps and Google Maps
The battery eventually gave up after 2 more hourse of standby. The Nokia website says the following about the Nokia E65 battery:
•BP-4L 1500 mAh Li-Po standard battery
•Talk time (maximum): GSM up to 11 hours; WCDMA up to 4h 40 min
•Standby time (maximum): GSM up to 18 days; WCDMA up to 20 days;WLAN idle up to 170 hours
If you are wanting to make comparisons with the Nokia E71 battery life, this is what the Nokia website claims for the Nokia E71. The Nokia E65 and E71 both use the same battery - BP-4L 1500 mAh Li-Po battery but E71 is slightly more demanding on the battery life.
•Talk time:- GSM up to 10 h 30 min- WCDMA up to 4 h 30 min
•Standby time:- GSM up to 17 days- WCDMA up to 20 days- WLAN idle up to 166 hours
If you are willing to help, maybe you can do the same experiment for your Nokia E65. Use the call logs and the data counter under "Connectivity" and measure how long your Nokia E63 battery lasts with "normal" usage. Report your findings in the comments below and someone just as curious as you googling battery life E65 will also benefit from your efforts.
Your mobile habits may not be as demanding as me but I hope this helped you in your battery life calculations for the Nokia E65.
To charge a battery from empty to full, it took 2 hours and 40 minutes
....... If you are willing to help, maybe you can do the same experiment ... It lasts me about 40 hours before I get a battery low warning .... I got my Nokia E65
Jan 05, 2011 | Nokia e65 Cellular Phone
How do I take my Nokia E65 mobile phone off silent?
Please press and hold # button for 3 seconds it will go to silent mode.To deactive do the same thing it will go general mode.
You can also use the manual.
Thank You
Aug 16, 2010 | Nokia e65 Cellular Phone
My nokia E65 phone is broken in half, can i still recover my sms and contacts from it and how.
Yes, its possible. i assume its upper part and lower part. fortunately, data is stored on the lower part components. you would use Nokia pc suite to recover your data. but may need to get a flex cable to power up your mobile.
Regards
Dec 09, 2009 | Nokia e65 Cellular Phone
I think my nokia slider strip has been broken
if your cell is displaying only white light on screen / sound failure/ screen not onning only buttons show light you ar probably right so you will need an exact match of the broken one
Aug 28, 2009 | Nokia e65 Cellular Phone
Can't recive multimedia Messages
1. Where r u from?
2. Who is your service provider?
May 22, 2009 | Nokia e65 Cellular Phone
Mobile phone unblocking
Unlock code for mobiles: click here.
Jun 10, 2008 | Nokia e65 Cellular Phone
Nokia E65 dead during Nokia Software Upgrade
I was just upgrading the Nokia software on my E65, connected with USB, charged and connected to charger for backup... and the phone just went dead. I've tried everything to get it going again including taking the batery out and outting it back in aain, holding the on/off button down for a minute - and nothing is happening. The screen is dead. Is Nokia's new upgrade causing this? I see two other posts to this site with the same problem in the past 24 hours. The upgrade was posted on Nokia.com 24 hours ago. my mail is singh1316@yahoo.co.in
Apr 10, 2008 | Nokia e65 Cellular Phone
Nokia e65
This is usually because you are running some application that interfears with the phone, try deleting your applications one at a time and checking whether the buttons work. When they start to work then the last app you deleted was the problem and you can instal the rest again.
Feb 12, 2008 | Nokia e65 Cellular Phone
Nokia e65 Cellular Phone Logo
582 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
