Question about Singer 5050 Mechanical Sewing Machine
I am trying to thread my singer 560 i cannot rember how to get it around the tentioner
It should go clockwise over the tentioner
Posted on Mar 06, 2009
Bottom tention thread loose
try adjusting the top thread tension up one number till the stitches look normal
Feb 07, 2012 | Singer Inspiration 4212 Mechanical Sewing...
I have a singer sewing machine model # 758 touch n sew and I cannot find how to set the bobbin thread tention. The thread bunches up under the bottom plate and adjusting the upper thread tention does not...
Hi, welcome to fixya, maybe I can be of some help
I checked on singer website & they have a free downloadable instruction manual in PDF form just follow the these steps
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 758 )& click search
the second one is free
Sep 10, 2011 | Singer Sewing Machines
Singer 522. when ever I finish sewing a piece and pull the threads out to cut the bobbin thread always comes out of the case so that when I start up it makes a mess. I have tried tightening the tention...
Sounds like the bobbin case spring is failing to hold the thread firmly - especially if you've already tried to adjust the tension and it hasn't fixed the problem.
I'd suggest you replace the bobbin case, preferrably with a Singer genuine part.
Mar 27, 2011 | Sewing Machines
Singer Simple `when not threaded runs forward and backwards,,,, `when threaded,,,,moves forward for an inch,,,and then looping clogs the bobbin area,,,it appears as one inch loops under fabric,,,have...
Try this test, with the presser foot down, pull on the top thread, it should feed smoothly, now lower the presser foot, the thread should barely move, when pulled. This sometimes seats the thread in the tension discs. Hope it helps you.
Nov 15, 2010 | Singer Featherweight II 117
Threading up a bobbin in a singer 560 sewing machine
I'm guessing it's probably the same as mine (8280). This is what the manual says: "Hold the bobbin case with one hand, insert the bobbin so that the thread runs in a clockwise direction. Pull the thread through the **** and under the finger. Hold the bobbin case by the hinged latch and insert into the shuttle." It's hard to describe, but if you've sewn before, it should come back quickly. To be more specific, hold the bobbin case in your left hand, insert the bobbin so the thread is coming up from underneath, pull thread through the **** and into the part where the hole is. If you slide the thread around, it will fit into the slot in there. Pull the latch out and insert it into the shuttle.
Hope this helps.
Mar 27, 2010 | Singer Sewing Machines
I have a Singer 15-98 and the bottom thread keeps bunching up??? What might the problem be?
the top thread tentioner was too loose and the thread was not seated in it. It is sewing like a champ! Thanks
Oct 07, 2009 | Singer Sewing Machines
Could not adjust both looper thread tention on singer ultralock
When servicing these machines I have found that the cover over the tensioners needs to be removed so you can see if there is more adjusting possible. If its a newer serger you would hold the knob somewhere in the middle (4-5) and adjust the knurled part that goes through it. Many times I have had to rebuild these tensioners as they get dirty and need cleaning and adjusting. It may take many tries until you have it adjusting correctly. But it needs to be done.
Feb 12, 2009 | Singer Sewing Machines
Singer 5050 Mechanical Sewing Machine Logo
270 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
