Question about Maytag MSD2756G Side by Side Refrigerator
How do you put the ice making compartment back together
The ice making compartment was not issuing ice, it was making it but it would not rotate to drop it down, my partner took it all apart and now can not put it back together again anyone know how
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Call service
Posted on Apr 06, 2009
Ice maker makes ice but will dispense through door. Checked and it is not clogged.
Good day!!!
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues. If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
I hope this information will be helpful...Thanks for using fixya...
Sep 09, 2011 | Hotpoint HSM25GFRSA
Error code is 1F - the fan has stopped working
My 2 year old LG LFX23961ST refrigerator started showing error code Er IF. In searching help here,
I found out it meant the problem was with the Ice maker Fan. When I checked the ports where the cold air blows into the Ice maker compartment, there was no cold air coming out (you have to hold the door switch in to turn on the fan). I removed the ice maker module (two screws) and unplugged it. When I closed the door, the fan started running, but was making a rattling noise. I suspected ice build up.
Emptying out the freezer compartment, I pulled the rear cover of the compartment off and found what I had suspected. Cleaned out the ice, put everything back together and Voila! Everything working again.
As I write this, I can hear ice dropping into the ice holding tray. Not sure yet why the whole ice blockage thing happened though. Will keep an eye on it. It's been several hours since the repair and no issues. All seems well. It's not rocket science. If you can use a screwdriver, you can fix it too.
Dec 20, 2010 | LG LFX23961ST Stainless Steel Bottom...
Indoor icemake is jammed
you don't mention a model or type of icemaker, but here is what I have done in the past.
Sometimes the ice melts together (door left open, etc). Take out all your ice and put into an ice chest, making sure that any large pieces are discarded or used elsewhere. Clean out any ice or pieces on the ice feeder screw or arm. Then close the door and make sure the screw it is rotating without any ice in it.
If all is OK, then put the ice back in and that should solve the problem. Good luck.
Dec 10, 2010 | Whirlpool Refrigerators
Bottom freezer/compressor works, top refer area not cold! I do not think the blower that transfers cold freezer air to the top is operational. I would like to know how to get at the fan motor, etc. to...
The fan that moves air into the fresh food compartment is in the freezer. If you open the freezer door and hear the fan, then you know it's ok. Gaining access to the fan motor requires removal of the freezer door, glides, and interior back cover. The door track system utilizes a rack and pinion type design, and if it's not put back together properly, the door will not close and seal.
If the fan is running, there is a motorized damper (flap) in the top rear of the fresh food compartment. If this damper is not opening as it should, the compartment will be warm.
The most common issue for you symptom is a defrost system component failure. Look on th interior back wall of your freezer for a build up of frost or ice. If this is the case, air flow is restricted because the evaporator col ice blocked with frost and ice. This repair also requires the removal of the door, glides, and evaporator cover. If you have any doubts of your ability to get the parts put back correctly, you should defer repairs to a qualified appliance service technician.
Nov 18, 2010 | Maytag MFF2557HES Stainless Steel French...
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Ice Maker does not produce Ice
Hello there. Yes. Open up the water filter compartment and make sure the water is flowing there. Right now it is airlocked. Get the water flowing and put it back together. If it still doesn't flow, repeat the process
Jun 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Aug 25, 2008 | Fisher and Paykel Active Smart E522B...
Flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
Apr 07, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Maytag MSD2756G Side by Side Refrigerator Logo
75 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
