Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Mixer turns on but the beater doesn't rotate - KitchenAid KSM150PS Artisan Series Stand Mixer
  • rekhabangar Apr 17, 2009
    I can hear the motor running/turning but this does not rotate the hook.
  • Rick Belanger
    Rick Belanger May 11, 2010
    Hi Matt. Were you mixing heavy dough at the time that it quit? Did you hear a CRACK sound when it quit? Is the mixer still under warranty? Do you have the ability to repair it yourself? Your answers to these questions will help me to diagnose your problem. Thanks, ricardok45
    Problem Solver:
  • 12 Answers
Remove the metalic ring around the mixing head. Push down on it with a flat head screwdriver...
Remove the pin from the mix shaft.
Pull down on the mixer head. Inspect the gears.
If nothing wrong here, disassemble completely and inspect drive gears. Something is broke and needs replaced. You need to find it first, then take that broken part to the dealer to get a new one. Good luck
Posted on Mar 16, 2009
My Sunbeam mixmaster quit spinning on bottom where the bowl sits
Does the bowl table rotate freely by hand? If not, it may need a squirt of spray lubricant. If the table rotates freely by hand but doesn't turn when mixing, look at the bottom of your beaters. The beater that is closer to the outside should have a nylon button at the bottom. This nylon button rotates the bowl as it turns. If the button is worn or missing, you will need to get new beaters.
Aug 18, 2016 | Sunbeam Food Mixers
Just replaced planetary and gears, flat beater still heating bowl. is planetary to be loose or fit tight against mixer head?
The beater cannot "heat" the bowl, so I am going to assume that is a typing error, and you meant hitting.
If the beater hits the bowl it is usually caused by the adjusting screw at rear of the column being improperly set. To correct this you need to turn the adjusting screw slightly to right, or left to adjust clearance. Clearance should be 1/16", about the thickness of a dime.
If this does not fix the problem, and the beater still rubs the bottom of the bowl, it can be corrected by tapping the yoke arm with a mallet, there should be 1/16" clearance between bottom of bowl and end of the beater.
You can determine the 1/16" by dropping a dime in the bowl, the flat beater should just "touch" the coin as the beater rotates.
If you have questions feel free to call us @ the Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid KP2671 Professional 6 Series...
The mixer runs but the beater doesn't turn. Drive shaft?
a gear or gears. their usually plastic and will damage before the drive shaft
Feb 07, 2013 | KitchenAid K45SS Classic Stand Mixer
Beaters are hitting each other and jamming up
One of the beaters had jumped a gear. I understand they are nylon gears. My wife's had the same trouble. I unplugged the mixer, removed the bowl and install the beaters if you can to see where they are touching. They were two cogs off. I grapped the left (red) beater firmly and twisted it to the left. It took a couple tries and turning on the motor (with out beaters) to find the spot where they had skipped. In the end the left beater jumped back one then two teeth and now the beaters aline properly.
This will happen again with heavy dough, etc. now that the teeth are worn in that spot. Use a bread machine for the heaver dough. IMHO
Dec 12, 2012 | Sunbeam 2346 Heritage MixMaster Series...
TURNED ON MIXER, BEATERS WOULD NOT ROTATE. ATTEMPTED TO REINSERT BEATERS TURNED ON AND MIXER STARTED TO SPARK. IS MIXER REPAIRABLE OR BETTER TO PURCHASE A NEW ONE?
You can try to replace the batteries again and see where that gets you.
As far as repair if the batteries don't work, I would recommend getting a new one.
Also check to see if it is still covered under the manufacturer's warranty period.
Good Luck
Jan 31, 2011 | Black & Decker MX55 PowerPro Hand Mixer
Wobbling on inside of mixer when beater is rotating
If the beaters are hitting the bottom of the bowl, try adjusting the upper-head stop-screw located near the top of the lower stand--it determines how far the head drops down and therefore, the height of the beaters above the bowl bottom. Hope this helps!
Dec 27, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
The mixer turn table won't turn? Its only a year old?
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
Dec 03, 2010 | Sunbeam Heritage 2346 Stand Mixer
I have a Sunbeam Mixmaster from mthe 1970s,
If this mixer sits on a stand, first remove it from the stand. Turn it upside down and shine a flashlight into the right side socket to look for obstructions. When you say you swivel the head, do you mean you rotate the handle? This is how to eject the beaters after use. It may be that the ejector on the right side is stuck. If so, you will need someone with mechanical skills to disassemble & repair.
May 23, 2017 | Sunbeam 2366 MixMaster Series Hand/Stand...
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Stand jumps
The height of the beater is easy to adjust on the tilt-head model.  Tilt the head back, and look into the pivot from the front of the mixer.  You should see a screw on the hinge.  With a flat blade screwdriver, rotate this screw half a turn counter-clockwise to raise the beater height.  Lower the head and check that the beater does not touch the bowl.  Repeat until the adjustment is satisfactory.  To lower the beater closer to the bowl, turn the screw clockwise instead.
Jan 12, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
442 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
