Tv shuts off automatically periodically
I Have a 52'' rear projection DLP by Viore. Model # RPT50V24DX/SMS. It tuens off automatically periodically when you first turn it on after a couple minutes or so. How can I Fix it
There is a switch located behind the lamp vent panel on the back of the set. Remove the vent panel and hold this switch in the down position while you turn the set on. The set should stay on as long as this switch is in the down position. If the set stays on, check the inside of the cover you just removed from the set. Locate where the switch rests against it and make sure that it is not broken. When you reinstall the vent cover, lay it flat against the back of the set and slide it down so it can catch the switch on the way down. Most times this switch will come loose and flip up while moving the set. Or if you just replaced a lamp and didn't get the switch back in the right position.
Posted on Mar 03, 2009
TRY TOPRESS THE SOURCE BUTTON ON SIDE OF TV. THIS WILL BE THE TOP BUTTON.
Posted on Aug 10, 2009
VIORE DLP goes off 30 seconds after i switch it on
Listen closely at the rear of the set for any noise from a fan. Most projection sets have them to cool high temperature areas common in these and if the fan fails, the set will shut itself off before any heat damage results. If you hear nothing, use a portable fan directed at visible openings in the lower cabinet and see if this delays the shut-off of the set. If so, the fan is likely dead.
Jul 30, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
Mar 12, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
TV turns off after a few minutes.
eso es mala configuracin de su tv revise el manual de usuario
Aug 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Viore model:RPT50V24DX/SMS shuts off and LAMP light blinks
Turn your set around. Locate the square access panel located on the lower right. Remove the 4 screws. Remove panel. Then push down tab on cooling box, it will look similar to a horn. Lift and remove. Lamp will be visible towards the back. Locate the pull handle,it is made of strong wire and it will be folded sideways. Pull open the handle. Look for screw on the left side of the lamp. It secures the lamp in place. Remove the screw completely. Now pull the handle firmly and voila! The lamp will slide out. To install new lamp just reverse the process. NOTE!!! Do not touch the lamp with bare hands. It will damage it. Wear surgical gloves or handle with a cotton cloth...
My 50 Viore dlp tv turns itself off after just a
HI, this may be a simple cooling issue. try inspecting the cooling fans that are located near the power sector. if these cooling devices are not operational, they will cause the power board to shut down periodically, due to heat build up.
If the fans are operational, this will confirm a weak and defective power power board.
Jul 20, 2009 | Televison & Video
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Televison & Video Logo
330 people viewed this question
Top Televison & Video Experts
Electro Med Services...
