Question about GE GSS20IEP Side by Side Refrigerator
Evap Fan not operating
Evap fan will not operate frost line is good The schematic does not show any voltages and is incomplete but I believe the motor is DC
  • 93 Answers
No the motor is ac the problem is the fan operates from the defrost timer find you defrost timer check your conection or reple it cost about 20,00 thanks from gilles
Posted on Mar 15, 2009
Maytag mcd2257kes - insufficient voltage to operate evaporator fan
Confused the condenser fan is in the back by the compressor and the evap fan is inside of the freezer which one did you change?
Jul 24, 2013 | Refrigerators
Low voltage at compressor!
My parts lookup too has no images available for you refrig but i believe it to be a GE Profile with a fresh food fan (and air duct down the center of the fresh food side). All fan motors are 12vdc and run off the Lowvoltage side of motherboard. i assume you are checking voltage to comp from motherboard? How did you check relay?? Have you axcessed motherboard?? On the top of (I say top-- i belive its mounted horiz on yours but all the small wires are on the right) is all the low voltage fan motor, damper, control wiring On the bottom (or the left) side of the motherboard is the larger line voltage wiring. The connector with 3 wires is labeled def -- comp---line it should be blue. Try jumping L1 to comp. ((Just so ya know Def will energize the def heater regardless of compartment temp it does have a bimetal but it only a safety set at 100deg in case relay on board welds shut---it monitor evap compartment, frz, fresh food, (two seperate in FF) in your model))
Oct 11, 2007 | GE PSI23MGN Side by Side Refrigerator
Evap fan runs constantly
The fan should run when the compressor runs.
Nov 23, 2012 | KitchenAid Refrigerators
Have you checked the capacitor on the unit. You will need a capacitor meter in or to check it. nI would check it first then the board. You check the board by running the one lead to the fan terminal and the other lead to the common and see if you have voltage. If you do not have voltage then the board is bad.
Mar 06, 2011 | Amana Heating & Cooling
No evaperater fan run,compressor running,coil is frosting but no voltage to inside fan.
Look to the fan delay/defrost terminator that is located inside to the evap. It is usually attached to the evap coil. check there first.
Aug 25, 2010 | True 206 cu. ft. Freezer TWT-67F
Door display reads ER FF
All error codes will display "ER" on the left side - that simply means error. In your case your error code is FF - which stands for freezer fan, or in technical terms, evap fan. Open your freezer and look for the vents where cool air blows out - do you feel any air coming out, do you hear the fan ? It is possible your evap fan stopped working or excessive frost around it - are you able to turn off unit and remove the back panel of your freezer held by screws, look for any excessive frost or anything blocking the evap fan - if there is no objects or frost blocking fan, then you have need to call service and have them replace your evaporator fan assembly - also note if your freezer fan is not working, then you won't get any cooling to either your freezer or your refrigerator - If you notice excessive frost and see that it is preventing your fan from operating you can use a blow dryer and defrost manually and see if it works again afterwards - if problem returns eventually then you have an auto defrost problem you will have to get it serviced and check the control board and defrost timer + components. Make sure you turn off refrigerator and unplug when checking things yourself at the back - if you are not comfortable doing this call service.
Sep 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
Aug 25, 2009 | GE Refrigerators
LG PTAC, compressor seems to work but fan isn't blowing
LG Has a Technical Service Bulletin for this issue. The original fan motors were too small and the motor windings burnt out. GOOD LUCK getting them to replace it though!! I was told by LG that the TSB extended the warranty so the repair would be covered. I have been waiting and fighting for 2 1/2 months though......they keep sending out the wrong or incomplete parts!! I am ready to go back to Amana or GE Zoneline.
Aug 08, 2009 | Heating & Cooling
Kenmore 253547
Heyy!!! A evap fan motor works in conjuction with compressor and condenser fan. If you purchased the unit new, then it should have a electrical schematic, post this, or you can interpret sketch, it will show you the details on what controls it. You can also sniff this motor and check it is burnt out. And by pass the leads to motor and check if it operates properly, replace if bad. Post your results if you want further help....Regards fmauka
Sep 18, 2007 | Kenmore 51562 / 51564 / 51569
GE GSS20IEP Side by Side Refrigerator Logo
73 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
