Question about Compaq Presario 2108CL (PF879UA) PC Notebook
My Compaq 2108Cl's battery gets turned off quickly and the power adapter cord is not removable from the laptop. What do I do?
  • klsax May 11, 2010
    what do u mean it gets turned off quickly? do u mean that u need to buy a new battery, because the one u have is bad? and how is the power adapter not removable? are u wanting to run on battery power? i guess i dont really understand what ur asking.
My screen does not turn on
  • Remove all power (adapter power Cord and Battery (for laptops))
  • Hold down the ON button for 30secs (dispersing internal voltage)
  • Plug the power cord in only (ie leave battery out, for the moment)
  • Turn on
Check your power adapter. Plug it in to a known good power receptacle. See if the power adapter has any lights that light up to make sure it is getting power.
Take the battery out of the laptop and just only plug in the power adapter.
Do any lights on the laptop light up when you power it on? Does it beep?Does it make a sound? Is where you plug your power adapter to your laptop loose or broken?
if no sound or light the its either power adapter , dc jack or cable, or system board .
Please note, it is also a good measure to re seat the memory.
You may need to locate your disassembly guide
Aug 14, 2014 | Compaq Presario R3000 Notebook
Good mrning. The battery of my Compaq presarioCQ40-310AU is not charging when the laptop is in use, unless it is turned off.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 27, 2011 | Compaq Computers & Internet
My compaq presario c500 wont turn on
Hello.
Hope this helps.
May 16, 2011 | HP Compaq Presario C500t Notebook
Compaq N610c does not power on on AC adapter or on Battery :(
it might be that the AC adapter is no more working. To confim this, remove the laptop battery and test the AC adapter with the laptop.
You can also borrow a friend's AC adapter and test it with your laptop.
I wish you good luck.
Mar 03, 2010 | Compaq Evo N610C Notebook
My hp ez4400 starts up but quickly shuts down ,
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Computers & Internet
HP Compaq nc6220 Laptop is dead. no lights,
Is this the same if the charger is also plugged in??
Remove battery and retry with charger plugged in.
If same battery charger is faulty.
Dec 22, 2009 | Compaq Hewlett Packard nc6220 PC Notebook
I have tried to recharge the battery and when turned on it just keeps beeoing is the battery bad
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 08, 2009 | Compaq Armada E500 Notebook
Hi Charlie, Thank you for your quick reply, The problem is I do not know how to check to see if it is a problem with the battery or if it is with the power cord. Although I am going off of the assumption...
Jul 18, 2009 | Acer Aspire 3690-2196 Notebook
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
HP Compaq plugged in & blue light on but icon says NOT plugged in
Check power out put of the adapter is it giving you the correct readings
Try to remove the battery and run it from adapter itself check to see if its working
Reset the battery ..by removing it from the system
Nov 10, 2008 | Compaq Presario Notebook
Compaq Presario 2108CL (PF879UA) PC Notebook Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
